screwy gas gauge
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87 mid canada k5, Jul 26, 2000.
  1. 87 mid canada k5
    87 mid canada k5 1/2 ton status
    Jul 20, 2000
    105
    Winnipeg Manitoba Canada
    gauge used to stop at one eighth, now it only goes down to a little over half before i run out of juice. doesn't seem to be electrical , is there a float in the gas tank that could be getting stuck? anybody? anyone? SOMEBODY?!
  2. rockosangel
    rockosangel 1/2 ton status
    Jul 11, 2000
    277
    Round Rock, TX
    There should be a float in your tank that registers the amount of gas you have left, but I would double check with others to make sure...I am not an expert on this Blazer thing....I am still learning myself.... It may also be your sending unit on the float that isn't working properly. Hope that helps you out a lil bit.
    http://www.rockosangel.coloradok5.com
    I'd rather push my Chevy than drive a Ford!
  3. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    its most likely your sending unit they are cheaper than a tow truck so i would replace it, for now you can just record the milage on each tank 25gal tank at 10mpg means you can go 250miles between fill ups
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I think the gas gauges on all K5s are all a little screwy. When i fill it up its like half an inch past full and when it says half its reall a third and you still have 5 gals. on empty. Also its fuller if you are going uphill
    90K5
  5. Canuck
    Canuck 1/2 ton status
    183
    Forrest, Manitoba, Canada
    I find that my guage goes quite a bit past the full mark but the top half of the tank lasts a long time compared to the bottom half.
    Canuck
    Go Wide or Stay @ Home
  6. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    I get the same thing i can go for about 2 weeks on the 1st half the second half goes like no tomorrow. That is very strange.
    J.D.
    88 Gmc Jimmy
  7. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    man when i turn cornors my gas tank goes from 1/2 tank to full tank on a turn...screwy aint it
    <font color=blue>If its too loud, your too old.</font color=blue>
    http://82Jimmy.coloradok5.com
  8. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    From all my experience reading post's on this board your sending unit is gone. You can change it yourself, but the gas-tank will have to be dropped. Or you can make a acces-panel through the bed.
    <font color=blue>Espen88k5 at:http://www.espen.coloradok5.com</font color=blue>
  9. 87 mid canada k5
    Jul 20, 2000
    105
    well i have to drop the tank to fix a rear shock mount, so it looks like i'll be checking the sending unit. geez you guys are great i'm almost getting teary eyed, but i'll save that for when i pull down the tank, again! HELLO G.M. A DRAIN PLUG WOULD SURE BE NICE!
  10. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I think sometimes baffles will come loose inside the tank and interfere with the float. From your symptoms, check for this when you drop the tank. I have never seen a gas tank with a drain in the bottom - safety concerns I'm sure. I used the fuel pump to pump the gas out of my pickup when I needed to replace a rusted out fuel line.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  11. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Blazer1970 had the same problem i had. There are two studs on the baffle in the fuel tank that have pressed on nut looking things to hold it down. Mine came off of one of these and made the baffle swing. Not only did it make the sending unit get messed up, it hit the fuel pump so hard that it knocked it half off the little hose in there. When it did that my TBI wasn't getting adequate pressure and my car almost didn't run at all. Hope this helps. - Doug
    Doug Krebs
  12. 87 mid canada k5
    Jul 20, 2000
    105
    thanks again, i hate to say this ( be nice now) but i think my 83 toy used to have a gas tank drain. ther's never that much gas in there anyhow, you think the prices are bad in the States, come up here and fill up.actually your 40 cent on the dollar discount might even things up! Later.
