Scrubbing Diffs
Discussion in 'The Garage' started by Russell, Apr 5, 2005.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    Hey guys!
    I'm working on cleaning up my K25's frame at the moment. I plan to coat it all with Zero Rust.
    What is the easiest way to clean a diff up yourself? My 10 bolt front diff is just covered and grease, and I doubt a wirewheel is going to work on it so good...
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'll be doing this in the summer. My plan was to hit it with a little bit of oven cleaner, and scrape off the bad stuff. Then wirewheel the light stuff.
    For your situation you could try oven cleaner to loosen it up?
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    If you have access to, or know where you can rent a hot water pressure washer, that would rock for cleaning that grease off. Maybe soak it with diesel or oven/brake cleaner before hand to soften it up even more beforehand.
  4. Russell
    Jun 23, 2000
    7,921
    331
    How hot does the water need to be? I've got a 2000 psi pressure washer, and a hot water tap on the side of the house. Or, will this damage my pressure washer?
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    blast a way with the cold and see what happens. and the pump is before the heater on the steam jennys. the one at work cleaned the dana 60 frt on my truck nice:cool1:
  6. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Had mine set up so it runs straight off the water heater and I never had any problems with it.
  7. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I am going to be doing this soon. I am going to sand then wash everything. Then I will hit it with Zero Rust. Post pics please.
    Adam
  8. Russell
    Jun 23, 2000
    7,921
    331
    I've got a fair bit of wire brushing / sand blasting left to do before I am ready for my zero rust.
    I'll be sure to post pics when I've got the frame coated though!
  9. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    What is zero rust?
  10. Russell
    Jun 23, 2000
    7,921
    331
    An excellent alternative to POR-15 and Rust Encapsulator.
    There is some info about it on their website, www.zerorust.com
