Scuba tank for air tank?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by simply_signs, Jul 29, 2003.
  1. simply_signs
    simply_signs Registered Member
    May 30, 2003
    9
    Not sure if this is the place to ask this question but I am thinking about using a scuba tank for a portable air tank. I was wondering if anyone has done this?
    A scuba tank can hold up to 3300psi. I would use about 2500psi and you can buy a regulator for the tank to bring the air pressure down so you dont blow your head off. A buddy of mine is into the scuba stuff. And he thinks it would work. I just thought I would ask if it has been done before.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    First of all, welcome to CK5.
    Second, I don't know how safe that would be. The top of a SCUBA tank can easily become a bullet if it is damaged. I would not risk it in my vehicle just for some air.
  3. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Yes - some people do it. You can buy regulators made specifically for scuba cylinders to put air in tires.
  4. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    The only problem with using SCUBA tanks for air is you need to be a certified diver or have a buddy who is to get them filled.
  5. CTBlaz45
    CTBlaz45 Registered Member
    May 16, 2003
    50
    Killingworth CT
    SCUBA tanks I don't think are any more dangerous then other compressed air tanks. I use one from time to time you get one maybe two fill ups with 35's aired down to around 13 psi.
