sea foam in gas tank?
Discussion in 'The Garage' started by bigarmzz, Sep 7, 2006.
  1. bigarmzz
    bigarmzz 1/2 ton status
    Feb 21, 2005
    184
    elkins, west virginia
    can you use sea foam poured directly into the gas tank?...i took my truck to a mechanic here locally, and he poured a hole can of sea foam into the gas tank, and it only had a half tank of gas:eek1:
    now the damn thing's smokin like a sumbitch:doah:
    was this a good idea?:confused:
  2. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    that just means its working. it'll clean it out and run better.
  3. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I wouldnt worry about it in the tank, I had a 95 f-150 with a 351 in it. It ran decent but had alot of miles and failed smog over 50 times the gross polluter limit. :eek1: After a good tune up I decided to run some sea foam through it after hearing some good things about it. I ran it through a vaccum source straight into the motor, smooked like hell, and sputtered like crazy until the can was empty. Ran good as ever after that. I think its kind of a snake oil type deal and isnt a cure all for an old motor but I dont think it could hurt to clear out some carbon deposites in the motor. But yes, running it through the gas is one way of injecting it into the engine and ocne its gone things will be back to normal. Let us know if you notice any difference.
    By the way my ford passed with flying colors after all, but it wasnt only the sea foam cleaning things out. I think it was mainly the good tune up, and the alcohol I ran in the tank.:D
  4. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    according to their website, you can use 1/3 to a full pint of it in the gas tank.....doesn't really mention how much gas it should be though. If anything, you can fill 'er up and then she may smoke a bit less.
  5. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
    We run straight SeaFoam right thru the fuel injected motors at work.. 2-strokes too... fill the fuel filters up with it and run em.. Does wonders...
    They also have a very nice penetrating oil called Deep Creep that rivals PB Blaster...
  6. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    were can I find this stuff? none of my part stores have it
  7. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    I bought mine at Napa.
    Per their website:
    http://www.seafoamsales.com/buy.htm
    It should be available at:
    ABC Auto Parts
    Advance Auto Parts
    Auto Value
    Bumper to Bumper
    CARQUEST Auto Parts
    Midway Auto Supply
    NAPA Auto Parts
    O'Reilly Auto Parts
    Parts Plus
    PEPBOYS Auto
    Pronto Auto Parts
  8. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
    Big in the marine biz too, so a marine store would probably have it, West Marine, etc...
  9. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    i put it in my gas tank all the time mine runs great :D
  10. NoReGrEtS
    Nov 7, 2005
    848
    Im retarded. View attachment 30110
    I just found it at pep boys. I was looking for some crazy lookig bottle not just some plan can. I have to do a smog by the end of the month.I hope I pass
