Sea Foam or Marvel Mystery oil?
Discussion in 'The Garage' started by tch777, Oct 8, 2004.
  1. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    I have a lifter that is sticking, and I want to try to "clean" it out so I don't have to replace it. Which one should I try? Has anyone used either successfully to do this? Clean out the gunk so the lifter is not ticking anymore and avoid tearing the engine apart to fix with a new set of lifters and cam?
    Tim
  2. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    My dad used to have good luck with Mystery Oil way back when.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Neither. 2 qts tranny fluid, 3 qts motor oil, run for 20 minutes at idle, drain, and fill with your favorite oil and a new filter.
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    What has worked for me in the past is taking the valve cover and rocker arm off, pull the pushrod and drain the oil out of it then stick it back in, then squirt some carb cleaner into the pushrod so it goes straight into the lifter. Ive done this twice so far and worked both times. Also, dont know if it would cure this problem but it might, old mechanics trick to clean out an engine is to put about a quart of kerosene in the engine and let it idle for 10 minutes or so, then change it. Same principle as the motor flush crap they sell for more money than its worth at the auto parts stores.
    Ken
  5. tch777
    Jan 15, 2003
    244
    Thanks for the replies
    Tim
  6. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    [/ QUOTE ] You can do the same thing w/ a gallon of diesel. Here's what you need;
    1 case oil
    2 oil filters
    1 gal. diesel
    Here's what you do;
    1. Drain the oil and remove old filter.
    2. Fill the 1st new filter w/ clean oil and install.
    3. Add 1 qt oil & 1 gal. diesel.
    4. Let idle for about 20 mins.
    5. Drain and remove filter.
    6. Fill 2nd new filter w/ oil and install.
    7. Top eng. off w/ oil.
    That gets a HUGE amount of gunk out of the engine. /forums/images/graemlins/thumb.gif
  7. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I've used Sea Foam before. Seems to work well.
  8. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    A quart of diesel fuel works good too. Just run it for a short time & then drain, & replace the oil & filter.
  9. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    that was going to be my recommendation /forums/images/graemlins/waytogo.gif good on ya , TIM /forums/images/graemlins/waytogo.gif
  10. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Id love to try them but Im afraid that it will losen up too much junk and maybe my truck will start to smoke regularly, I dunno Im just apprehensive. Any reason I should worry like that?
  11. tch777
    Jan 15, 2003
    244
    Well I just got the Gunk motor flush and did that.
    The diesel thing didn't fly with the wify, I got that your going to do what to my Suburban look. But that motor flush is just like diesel smells and pours that same, but has a red tint. I then changed the oil and filter and did a dose of sea foam for good measure. We Will see how things run next week. But it is idling much smoother right now. I am going to change the oil at 1000 miles this time just in case things are still getting cleaned out.
    Tim
  12. blind driver
    blind driver Registered Member
    Oct 9, 2004
    11
    Louisville, KY
    You just flushed the engine with deisel fuel /forums/images/graemlins/rotfl.gif. Offroad diesel is red. I always used transmission fluid. /forums/images/graemlins/thumb.gif
    Valvoline makes a engine additive that eliminates lifter tick. Available at a VIOC near you. /forums/images/graemlins/waytogo.gif
  13. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    True, GM also has a litfter additive. Guess they were planning for things to come....
