Seafoam???
Discussion in 'The Garage' started by trev1981, Apr 4, 2007.
  1. trev1981
    trev1981 Registered Member
    Dec 21, 2006
    72
    Manteca, CA
    Has anyone ever put that stuff called "Seafoam" in there motor?
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    yup, workes wonders. ATF will do basically the same thing. It makes lots of smoke.
  3. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    It's all about "garunteed to pass". Garunteed to pass smog or double your money back. I just put some in my truck after my buddy had a good experience with it. My truck starts right up now in the morning and runs better than it did I think
  4. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I use it when I am getting a rig running thats been setting for a long period. seems to work good for that.
  5. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Yeah, but ATF will usually kill a Caty converter. I used the seafoam to clean mine out when I was having a nagging ping problem, and plan to do it again after I put on a few more miles.
  6. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    How are you using to help with the pinging? Are you sucking it in thru a vaccuum port or putting it down the carb?
  7. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    I've used it on my '87 and on my wife's 2000 Tahoe when she hit 100k. Both with good success. On my wife's Hoe the SES light came on for a while but it cleared. I bet it was one of the 4 O2 sensors reacting to all that smoke coming thru the pipe.
  8. kp texan
    kp texan 1/2 ton status
    Sep 8, 2003
    211
    Corpus Christi, TX
    How exactly do you get it into the engine? Just pour it into the throttle body or carburetor?
    -Wes
  9. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    pull the line off of the brake booster and hold your hand over it. makesure the engine does not shut off and put it in the can of seafoam and let it slowly suck up the seafoam. then shut then engine off and let it set for maybe 20 mins. there ya go. happy smoking up the neighborhood
  10. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    I pulled the hose off the throttle body hat goes to the pcv valve and used a piece of hose I had laying around. Put the hose on the vacume port and into the can and had my wife start the rig (after warming up with about a 10 miniute drive prior). Sucked in about 1/2 the can and had her shut it off. Let it sit while I hand luch then came back and started it up and ran it out. Drove around for 10 minutes and repeated.
    You should have seen the crap come out of the pipe on the 2nd cleaning!
  11. bluehen
    Nov 11, 2004
    215
    DE
    On my K5 I poured it down the throttle body since I know it will hit all the cylinders. On the Hoe I pulled the pcv tube, spun it around, set a small funnel in it, and poured into it.
  12. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    How do you do it with a carb? Pour it down?????????????
  13. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Carb should have PCV hose as well, or use the power brake port. If all else fails you could pour it in as well. I think the can has instructions.
  14. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I'm confused. If it puts out a bunch of smoke I take it you have to let that clear out and drive it right to the DMV for inspection? Whats it actually doing to the internals?
  15. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Cleaning out carbon buildup....
  16. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    Where can i get some? and would it be recomended for my 1 year old 355 tbi? probaly only 15,000km at the most on it
  17. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    I thought that was a typo, then I saw where you live.
  18. otisringle
    otisringle 1/2 ton status
    Aug 2, 2005
    148
    california
    I asked this question a while ago, and if I remeber corectly some said not to use it because it will screw up the engine because the carbon being cleaned off made it dirtier in other areas or something like that. I could be wrong though.
  19. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    worked wonders in like 10 different trucks that i've used it in.
  20. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    yup, seafoam rules.. we use it HEAVILY in the marine biz...
    I just shock treated my K5 with 2 cans to the gas tank and it cleared up a sticky injector... It's also good used as a fuel maintenence item, throw a can in the tank 3, 4 times a year...
    And yup, does wonders for combustion chambers too with a direct dose...
