Seal between 700r4 and NP208 adapter?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SAVAGE1, Feb 25, 2002.
  1. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I installed my new engine and transmission yesterday and then realized that I didn't look to make sure there was a seal between the tranny and the tranny/Tcase adapter. Is there supposed to be a seal or O ring in between? I want to know for sure before I pull the Tcase. Does fluid from the tranny spill through to the Tcase?
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers 14Bolt/ Dana44 4.10's
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    on my th350/205, the seal was only to keep fluid from the tranny from leaking out between the back of the tranny and the adapter. the 205 had its own input seal, which kept the atf and gear lube from combining. there was an O ring on my combo, rtv works too.
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I believe there is a paper gasket available, I've always just RTV'd it.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  4. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Ther is a seal on the input shaft of the t-case. As far as the adapter goes RTV works, JUST FINE.
    IT'S MOSTLY MAUI WAUI.... BUT IT'S GOT SOME LABRADOR IN IT
  5. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Thanks guys, I guess its RTV time.
    Rod
    Alameda, CA
