Sealant on oil pan gasket?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stoopalini, Sep 5, 2001.
  1. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I just finished replacing the rear main seal, and am ready to reinstall the oil pan. The old gasket had sealant on it (silicone) and I'm wondering if you guys recommend putting some on the new seal?
    Thanks for speedy replies, I'm tired and would like to go to bed [​IMG]
    Thomas.
    -- '84 K5 Blazer --
    <a target="_blank" href=http://stoopalini.off-road.ws/blazer>My Blazer Site</a>
  2. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    If you're using the rubber one piece gasket with the metal framing bonded into it, don't use an additional sealer. This gasket is pretty amazing about not leaking. I'm using one, and have zero leakage.
    I usually rub a little grease around the gasket face if I'm not adding sealer to them. It makes them a little less likely to tear when tightening.
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**
  3. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    The gasket I'm using is a 4 piece. 2 long strips of cork, and 2 u-shaped rubber pieces for the ends.
    Do these require sealant?
    Thanks,
    Thomas.
    -- '84 K5 Blazer --
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I usually put a little Gasgacinch or Copper-Kote on them - it's my luck that if I don't, the damned thing will start leaking like there's no tomorrow.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    I use Loctite Aviation Gasket Sealent No 3 (non-hardening) on cork and paper....works goood.
