SEALED BEAMS?
Discussion in 'The Garage' started by CHEVY 4WD, Mar 6, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    What would happen if you drilled a hole in a sealed beam(HEADLIGHT) I was thinking of putting strobe lights in there(and no im not turning into a ricer). /forums/images/graemlins/confused.gif
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    The bulbs would over heat and burn out in short order. They do make strobe kits for head lights.
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    What would make em burn out?
  4. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    Oxygen. I believe sealed beams contain an inert gas, probably nitrogen.
  5. 98sub454
    98sub454 Registered Member
    Jul 18, 2002
    74
    La Habra, CA
    yeah they are filled with a gas, and if they are opened up they will burn out very quickly
  6. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Indeed.
  7. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    better check your local laws- strobes are illegal here without a fire/emt permit...
  8. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Yea there illeagle but If im not on the road its ok /forums/images/graemlins/thumb.gif
  9. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    You could do it if you went out and bought the H4 conversions for them. The cheapest assemblies that i have seen are about $20 each then another $20 for the bulbs. That way you can run your... um... cool lights. And some PIAAs or whatever else you heart desires.
