Sealing between T-case and the TH350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ankarback, Oct 27, 2003.
  1. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    I removed the T-case yesterday to replace it with a better one and found some kind of thick sealing between the T-case (NP203) and the TH350 automatic. What does it do, it´s no oil there that can leak out. Do I need to replace it or can I just remove the old sealing and put the new T-case in.
    Need some opinions on what to do.
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    That seal keeps the tranny fluid in the tranny and stops it from leaking into the T-case.
    Rene
  3. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    If you look into the end of the TH350, you will notice there is a bushing pressed into the hole where the tailshaft comes through. The bushing is fed with trans fluid which lubricates the tailshaft. There is a small hole below the tailshaft where the fluid (which enters the space between transmission and transfer case) drains back into the trans pan. The round oring seal keeps the fluid from leaking on the floor. The transfer case may have its own internal seal near the input bearing to prevent trans fluid from entering.
  4. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    Thanks for the info /forums/images/graemlins/thumb.gif
    I have to find a new one then.
  5. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    Go to your local tranny shops. they usually have 1 or 2 laying around out some kits they may have used . I found one that way and it was free.
