Sealing bleeder screws?
Discussion in 'The Garage' started by dremu, Mar 22, 2006.
  1. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    I know that sealant is A Bad Thing on the inverted flares, as the threads just push the flare down, and the flare is what seals.
    But on the bleeder screws, the bottom (non inverted) flare is what seals when in use ... and the threads seal when they're cracked and I'm trying to bleed. Even on new (reman) calipers with new screws, I get some leakage around them, which I think is causing me grief.
    I see some of the bleeders come with some kinda goo on them, maybe antisneeze ... so, the question: is teflon tape or rectum-seal okay for those threads, as long as I keep it the hell away from the bottom of the bleeder?
    -- A
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I would just use some antisneeze
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A bit of leakage around the threads is normal when you loosen the bleeder screws. Only open the bleeder 1/2-3/4 of a turn and snug it up tight before the pedal is let up. When the bleeder it tightened it won't leak at all.
  4. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    another thing...
    I've noticed nearly every bleeder screw that has the rubber cap still over the end always comes loose easily,no matter how rusted the caliper or cylinder is.....and nearly every one without one snaps off almost without fail!...
    I guess the water goes right to the tapered seat and rusts it to the caliper or wheel cylinder,even with never seize on the threads they snap off ...so I try to save those caps,or at least put a dab of grease or silicone over the bleeder nipple end..it does help!..only takes 1 year here for them to rust solid..:doah:
  5. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    You might want to try a set of these http://www.speedbleeder.com/. I have the same problem with the bleed screws on my Dana-60. Using a vacuum pump to bleed my front brakes is useless with the air being sucked right through the bleeder screw threads, which is why when I bleed the fronts on my truck, The pressure pushing out the air has to come from the master cylinder (pushing down to the calipers), as apposed to my vacuum pump, which pulls the air out from the caliper.
  6. dremu
    Feb 27, 2000
    15,963
    454
    Yeah, I've messed with the speedbleeders -- Motormite sells 'em now even -- but I find they are an additional cost and hassle. I've had just as good luck with pressure-bleeding with traditional screws.
    And yeah, vacuum bleeding sucks -- literally =)) I had the same experience of air being pulled through the bleeder threads, so I've switched back to pressure bleeding with the garden sprayer.
    -- A
