Sealing intake
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mouse, Jul 7, 2005.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    After tracking down all the oil leaks on the new motor in May, I changed the intake gasket along with all the other required, leaky ones. After a short time, the front rubber started to push out, just behind the alternator. It eventually got bad enough where it started to leak oil. When I could no longer stand looking at the leak (last weekend) I changed the intake gasket again. A little over a week later, the new gasket is now pushing out, and has started a slow leak.
    When I first assembled the engine, I used RTV, and not the rubber pieces to seal the end of the intake. I guess this is the route I will take when I change it again. It must be the higher oil pressure from the high volume oil pump that is contributing to this, but I've never had such a problem on many, many other engines. The PCV valve is working, and in good shape.
    Any suggestions?
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I have never had a problem using RTV sealent on the front and rear. I found that the larger the bead I put the better. Also it took me a few rebuilds to figure out that I needed to coat the bolts holding the intake on with RTV to keep oil from leaking. Just my 02 cents hope it helps.
    James
  3. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    all gm intakes should have note in gasket box. ( take end gaskets and put them in the trash. ) just make sure all clean and 1/4" thich bead on ends. also coat bolts with it as thay go into the valley area.
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    DO yourself a favor and use a gasket maker material called "The Right Stuff". You'll wonder why you ever used anything else.
  5. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    I was pretty sure I was going to use RTV this third (and hopefully last) time sealing the intake. I have been using thread sealand on the bolts - The first time I used RTV and a couple still leaked. The second time I used the white teflon thread sealant and had one leak. This last time I used the brown colored thread sealant, and everything is tight....except that darn rubber end piece.
    Thanks for convincing me to go the RTV route. I'm not looking forward to draining the coolant, resetting the timing yet another time, but I guess it must be done. Having an oil leak just plain sucks, especially on a new motor.
  6. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Intake gaskets
    Fel Pro Perma torque performance gaskets.. (Unless your using an aftermarket edelbrock manifold then follow their recommendations)
    Use CATERPILLAR gasket sealant ... its green in color... 9.50 a can but worth every penny...use it on both sides of the gasket and manifold...
    Lastly as the other poster stated use "The right stuff"... skip the chevy rubber end seals...they are notorious for leaking...and blowing out,,, just use a nice thick bead of the right stuff and let it squish out... after if dries you can cut it off cleanly with an exacto
    Make sure all surfaces are clean and oil free....
    It won't leak if you do it this way...
    Believe me...I feel your pain..Ive been there
    cam
  7. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    :haha: :haha: :haha: My dad worked for GM for 25 years and when he showed me on my first truck he said they had a tech bulletin that said almost exactly that.
  8. Madbomber88
    Madbomber88 1/2 ton status
    Feb 7, 2001
    185
    Mass
    I second the "Right Stuff" recommendation. That stuff is second to none
  9. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    I bought some "Right Stuff" today....it cost more than the FELPRO intake gasket. It will be well worth it it if everything selas up tomorrow.
    Then I'm going to takle the install of the hydroboost system I bought.....
  10. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    I beleive it was worded like this
    "discard rubber end seals" and probably recomended some GM P/N RTV sealer
