Sealing up an np205 with RTV instead of the "felt gaskets"?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Apr 12, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Sealing up an np205 with RTV instead of the \"felt gaskets\"?
    I was wondering if any of you have had luck with using RTV Gasket Maker to seal up a 205 instead of the 'factory' felt gaskets? I need to tear my 205 apart this weekend and paint it and was wodering if I whould have better sealing capability with RTV or the felt gaskets....
    Thanks in advance....
    Chris
  2. dyeager535
    26,977
    Re: Sealing up an np205 with RTV instead of the \"felt gaskets\"?
    I think the normal gasket would work better. I just have a feeling anything else won't seal well. One idea, you can buy those sheets of gasket material now, make your own! Only like $2/sheet I think, depending on the type of material.
  3. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Where can you get the "sheet" of gasket material? Id be very interested in doing that...
    Chris
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I got a whole pack of different gasket material at Napa. They had different materials for different types of gaskets, it was pretty sweet. I think it was like $15 or so. But you got a couple sheets of 4 different materials. I had to make a gasket for an oil filter adapter on my buddies Heep, so I bought the make yourown sheets because you can get that gasket anywhere. I now carry all the stuff I didn't use in my truck incase I need it on the trail.
  5. dyeager535
    26,977
    As Hoss said, Napa, or any other auto parts store anymore apparently. Schucks carries it up here.
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think the bearing retainers require the gasket in place to provide clearance for the snap ring retainers.
    mic it to see
