seals around D60 upper kingpen?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Toledo, Jun 24, 2003.
  1. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
    just got done putting my D60 back together minus the small seals that fit around the upper kingpen. How important are these and would you pull it all the way back down to add them?
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    If you used RTV or similar product, I wouldn't worry about it, if not, they will probably leak a little grease.
  3. Toledo
    Dec 10, 2001
    207
    no its a small ruber seal that actually slides down on the pin itself. forms a seal between the pin and knuckle.
  4. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    if you grease the kingpin like you should-no big deal. I always had a rule every 3000 miles or if it goes under mud/water-then it's time to grease. Steve
  5. Toledo
    Dec 10, 2001
    207
    K Thats kinda what I was thinkin. Not a lot of precision working parts so I didnt think it should matter to much.
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah, i did the same thing...
    i have the seals, and one got put on. im just waiting to put my crossover stuff on to put the other on.
    Grant
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Does anyone have pics of a kingpin R&R? I'd like to show them to a guy at work that insists kingpins are only on 2wd trucks. We don't stock the pins at Autozone so I can't show him. Well, if we do, I can't find them, and I sure did try. Even looked in the paper catalogs.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    PERFECT!! Thanks mj.
