search is dead, crossover steering installing?
Discussion in 'The Garage' started by aj_tatted, Jan 21, 2004.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    what all do i need to complete crossover steering, i have the 2 wheel drive steering box as well as the arm and the right side flat top knuckle. WHAT ELSE?
    i need step by step!!
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Since you have an 80's 10 bolt up front, you will need the other style knuckle to have the same tie-rod attachment, unless you found a flattop that has tierod entry from the bottom.
    1. You need to have that flatttop drilled and tapped for the steering arm to bolt to.
    2. crossover steering arm to bolt to that knuckle.
    3. dropped draglink and ends.
    4. Superlift ford pitman arm to connect ot your 2wd box.
    Some things to consider are new ball joints and new tierod ends while you are working this project. You need to give it a "tape measure" alignment while you are at it.
    Blake
