Searched (but still can't find answer)
Discussion in 'The Garage' started by titus95, Sep 20, 2005.
  1. titus95
    titus95 Registered Member
    Sep 16, 2005
    12
    Lincoln, NE
    Question on U-Joints:
    Can they make a squeeling or squeeking noise like a belt if they are going bad? It happens in low gear (1st). I want to change them but I can't seem to find a nut or bolt that holds them in...there are pins how do I get them out? Appreciate the info.
    Ben
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    If it's a u-joint like this one:
    Then there's 4 blots each on 2 each metal clamps. U-joint is held in the driveshaft with C-clips. Don't ask why that one's connected to the pinion with no driveshaft :(
  3. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    The pins your talking about are plastic. If you heat them up with a torch the melt. They come out like those snake firework things.
  4. titus95
    Sep 16, 2005
    12
    Lincoln, NE
    I'm sorry to make things confusing...I know there are four bolts that mount into the pumpkin (U-Joint) but what about the U-Joints that are directly out of the T-Case...are those the plastic pins that one is able to melt...otherwise it looks like someone sheared the heads off a very small bolt. Thanks again.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    They should press out after you remove the internal c-clip
  6. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    yes they can squeak!!
    Often bad U-joints make a RRRRR-EEEEE---RRRRRR-EEEEE squeaking noise when backing up or going forward slowly--noise increases speed as the driveshaft does,until you get to 30mph or so,where it may or may not "go away"--actually it does not "go away"--its just going so fast its harder to hear!---what your hearing is dry,rusted caps with no needle bearings rubbing against the journals on the "cross"...you have about 0-50 miles left after this noise starts in before your towed to the nearest service station--and sometimes junkyard to look for another driveshaft! :doah: :eek1: :crazy:
  7. 4wheelattitude
    4wheelattitude 1/2 ton status
    Aug 5, 2005
    145
    central Illinois
    Are you certain its the joints making the noise? Before you go through alot of trouble.
  8. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Or sometimes they don't make any noise and your driveshaft shears off of the U-joint (see above photo) :mad:
