searched: where to buy vent tube?
Discussion in 'The Garage' started by BranndonC, Nov 29, 2003.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i need a vent tube adaptor thing (the part that plugs into the axle it self for the hose to connect to) and cant find where to buy one. i called the local shop and they aere no help.
    The axle is an 84 D60
    The local yard has no 60's so will any vent tube fit?
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Under the part # database in the bloody knuckle I posted the GM part # for it. This was back when I was a member.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Just tap the hole for 1/8" pipe and buy a thread-in fitting. I did this to my D60 axle since my vent tube fitting was missing. /forums/images/graemlins/thumb.gif
  4. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i even used the part number at the dealership and they said they didnt have it and "maybe but doubtful" that a warehouse back east had 1...
    if i tapped it to 1/8 how would i connect that to the tube?
  5. zcarczar
    Feb 10, 2002
    2,495
    Branndon, want me to see if I can get you one? Sounds like the dealer you went to was retarted. They should be able to order you one.
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    would love one.. any way i can get it.. lol go ahead and check if you can get me one please. and if it is in a east coast wearhouse they can just ship it to the dealership around the corner from me right? Thanks jason.
    BTW my ORD steering box reinforcement plate arrives monday /forums/images/graemlins/wink.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You would then buy an 1/8" pipe to 5/16" nipple or whatever size hose you are going to run to the differential and screw that into the housing then attach the hose to it.
  8. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    i could use one of these too... 85 D60...
    j
  9. 83_chevy_blazer
    83_chevy_blazer Registered Member
    Nov 18, 2003
    20
    i made my own. i reised all my vent tubes to the firewall level. i used these brass fittinbgs i got at dixiline. im prety sure theyre for gas routing. anyway they have a treaded side and the other side is a male fitting with 4 ridges. i believe the thred side was 1/4 in diameter, either way it was a tiny bit too big so i beveled it down with the grindstone. then i put some gasket maker on it and bashed it into the hole. i did this for my 12 bolt rear, transfer case, and transmition. i used clear nylon tubing for the hose and little fish tank bubble stones for breather caps. the fish tank bubblers attach by glueing a little bit of the fish tank hose into the breather hose.
  10. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    I need one for my rear 10 bolt. If anyone can find me one with the threads still good I will gladly paypal or send money order.
  11. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I did the same as mentioned above. I used a 1/8" NPT tap (with some grease on it to catch chips as I did it without changing the fluid). I then bought a 1/8" NPT x whatever barb fitting. I haven't had good luck with the pressed in ones...they just pull out and let water, dirt, and mud in. The tap will set you back about $8 but the fittings are like $.95 You should put one in your tranny as well as they don't come with a vent line (ask me how I know /forums/images/graemlins/angryfire.gif).
  12. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Hey will one from a Dana 44 work? Or a 14B or a 10b?
  13. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The reason I went with the threaded in one is because my old D44 had a thread in one on it from the factory. When I got my new D44 (1977 - 2nd design 3/4-ton) it had a pressed in one that was loose. I liked the way a brass fitting pointed straight up so that is what I used. I haven't messed with the 14B yet as it hasen't come out.
  14. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    OK how do I get the tube out of the axle???
  15. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Big pair of pliars and a twisting motion.
  16. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    YUP use a hose barb and small hose clamp for the best sealing /forums/images/graemlins/thumb.gif
  17. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Or like in my case (mine are broke off) you can drill them out. And as mentioned before, put grease on the drill bit to catch the filings.
  18. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Be gentle...I need that vent tube /forums/images/graemlins/deal.gif
  19. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    on my 10bolt I just rebuilt has been drilled out, tapped and has an airbrake fitting, I just used a hose clamp and it works great.
  20. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    My fronts okay, but after my lift I needed to put a longer vent hose on the rear and went to pull the old hose off and the whole dang tube came out /forums/images/graemlins/confused.gif so I need one for the rear. However this is all temporary till I find a 14 bolt to swap in like you did Fry /forums/images/graemlins/grin.gif
