Searching for 6 lug 14ff
Discussion in 'The Garage' started by bluejeep, Mar 7, 2005.
  1. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    A while back I came across somebody's webshots of a 6 lug 14ff they had done, retaining the 14ff's drum brakes. It was on a K5 blazer. Does anybody have these pics or a link to these pics? Tried searching with no luck.
    Going to try to put a 14ff in the Suburban, and since there isn't a good way to change the front over to 8 lug I'm looking to change the rear over to 6 lug. I'm not interested in Grady's hubs or anything like that. I have a machinist lined up to do it, just need to provide him specs and/or pics of what I want done. I also want to keep the 13" drums for e-brake reasons, and because the 13" drums are pretty darn good at stopping a big heavy truck pulling a trailer.
    Thanks.
  2. blacksheep10
    blacksheep10 Registered Member
    Feb 16, 2005
    37
    Paola, KS
    i am sorry that I don't have the answer to where the pics of the 6 lug 14 is, but I have to ask what year burb this is. If it is under 91, why is it hard to make the front 8 lug? Should be really really easy to do with some new hubs/rotors/wheels. Just a thought
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Look in the for sale section. I think that guy is selling the 6lug 14ff your talking about. He's going eight lug now
  4. bluejeep
    Jan 9, 2004
    106
    Des Moines, IA
    It's not under '91, that's why it's not easy. It's a '99.
    I'll check the FS board now.
  5. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Haha, ah yes, the super-rare 6 lug 14 boult FF
    here's a pic of mine...
  6. bluejeep
    Jan 9, 2004
    106
    Des Moines, IA
    There we go.
    More pics/details please B_to_C!! What hub diameter did you use, 4.20"? Did you have to bore the center of those wheels any?
    BTW, the one in the FS section is using spacer/adapters, and I'm looking to modify the stock hubs with no spacer.
  7. B_to_C
    Jan 15, 2003
    1,861
    I am using adapters. 4.20" sounds familiar, but i don't remember the exact diameter the hub was machined down to, sorry. And yes the wheels had to be clearanced a little too -but to do that I just took a 3" grinder wheel around the inside of the hole, only needed to take a little off. Those 13" brakes really do kick ass at stopping though, I love 'em.
  8. bluejeep
    Jan 9, 2004
    106
    Des Moines, IA
    Is there plenty of room to get a socket on your lugs? Did you have to remove two of your studs to run the spacers?
  9. B_to_C
    Jan 15, 2003
    1,861
    It looks real tight, but I have no problem getting those lugs off, and yes you have to remove two of the studs to run the adpaters. Here is a view from the back
  10. bluejeep
    Jan 9, 2004
    106
    Des Moines, IA
  11. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I have adapters too ToneyP made them idk if he does it anymore but all I had to do with have the hubs turned down and dident bore the wheel at all but it is REALLY tight I also stuck disk breaks on. I just think its a good idea...
  12. B_to_C
    Jan 15, 2003
    1,861
    I love my setup. I would have probably done the 8-lug swap if I had had the time though, but as it was I was rushed to get this rear axle in. But I don't have any ill effects to report :)
    And btw my adapters are also from TonyP, and AFAIK he is no longer making them.
