searching for homebrewed cadillac e-brake lever
Discussion in 'The Garage' started by BranndonC, Feb 14, 2006.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I saw a post before where someone used a wrench on their caddy caliper for the rear e-brake
    i really want to get my e-brake working, and cant seem to find any post with good pics or any part store who knows anything. so either i'll have to rig my own or find the stock parts. cant anyone help me?
    76-78 eldo rear calipers is what i have
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Thats was me:D
    Let me see if I can find the pic.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Here ya go.
    I still have the one that I made, I ended up cutting off the back half and actually making it look good. I could send it to ya if ya want:D
  4. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i cant afford the shipping, could you explain whats required a little better? thanks man :)
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    verticle plate to axle, cable through that to wrench?
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Yea the plate is just welded to the top of the axle tube. I believe the hole is 1/2" but it needs to be able to have the cable snap into the hole.
    Next bolt the wrench to the caliperand turn it counter clockwise till it runs out of slack (you will know what I mean when you try it). Then you need to fab up the little bracket with a slot cut into it for the cable to slide into. Next just weld a little cap over the hole to keep the cable in there.
    Now just hold the bracket up to the wrench and weld it in.
    Did that make sense?? :crazy:
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    makes sence, but whats the springy part over the cable, should i have that already? oh and did it work well?
  8. dyeager535
    26,982
    191
    Is there any reason somebody isn't making these levers?
    I mean we are seeing 3 speed transfercases, and new gearsets for 205's, and somebody can't make stamped steel e-brake levers? :)
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    x2
    Someone get Kert from DIY4X in this thread.
  10. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    word Leper, that man can build anything imo
  11. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i think that he is working on the levers, i sent him one i had to go off of
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea the spring is on the cable stock.
    I only ever got around to hooking up the 1 side but with just that one side it would hold my blzer VERY well on a hill (my driveway).
  13. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Last time I checked which was about 1.5 years ago I could still get them from AC Delco, find a good parts guy and they can get them for you, they are under brake hardware.
  14. Bushido
    Bushido Registered Member
    Jan 25, 2006
    38
    Hawaii
    Collecting parts to build my 14bff.Will be doing the disc conversion,are you guys reusing the stock cables from the drum brakes?
  15. dyeager535
    26,982
    191
    I know the springs available are for the wrong calipers, IIRC, you can still get levers as well, but not for the '76-78 Eldo stuff. :(
  16. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Yep, still got the lever too! It's actually a fairly complex piece for its size. Something that would really help would be pictures of someones setup with all the levers in place and cables hooked up. The ones with the wrench will work but I need a view from straight on. I mean, taken from above the axle tube.
  17. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    If you get the dimensions of the little hex part, a machine shop should be able to have a hexagonal die that they can just stamp that part out and you can bend part of it to put in the cable. Thats what im going to be doing.
  18. dyeager535
    26,982
    191
  19. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    my caddy calipers
    just put the first side of mine on last night and should be finished with the entire setup sometime in the next week...ill throw pics of mine up when im done.
