seat belt lengths
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jan 8, 2002.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Im getting a rear seat and I need to know how long the seat belts for it need to be. If someone could measure theirs and let me know what the length of the whole belt is from end to end it would help me a lot because right now i dont know if I should get the 60" 74" or the 90" belts out of the JC Whitney catalog
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  2. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    If you know the approximate seat height(seat to floor) double that(to count both sides) then use a piece of string or a seamstres' tape and measure yourself sitting on the floor that should give you an idea. Keep in mind that if you plan to haul people larger than yourself back there to add some length. Since there are only three sizes this should help you narrow it down.
    If you knew the truth, you too would be against marijuana prohibition!
    Blue '74 K5 Blazer Topless W/ 35 BFG Muds
