Seat frame
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JROSS, Dec 5, 2001.
  1. JROSS
    JROSS 1/2 ton status
    Oct 12, 2001
    281
    Redding, CA
    Does anyone know where I could get the seat frame for the passenger side. After I bought the Blazer I noticed the passenger seat had a lean to it. After some investigating I notice the frame was put under to much load.
    81 Blazer Silverado Package, 350, 4" lift, 35" tires
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I've seen them in junkyards. Usually about $75. I'd go with aftermarket seats and install them instead. I got mine out a 95 Honda Accord for $50! Took some work to put them in tho![​IMG] But you figure you hafta to get the junkyard seat reupholstered anyhow............
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. JROSS
    Oct 12, 2001
    281
    Redding, CA
    The thing is the actual seat is in great condition, not worth replacing. Its the frame part that hinges foward for acess to the back seat that is bent.
    Do all the 80's blazers have the same int components?
  4. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Ok I gotcha. My whole seat back broke in half.. Its just thin tin and when I got rearended it kinda gave up the ghost!
    Jim
  5. dyeager535
    26,980
    No, '86 was first year of passenger (and driver too I believe) that hinge at the back and then slide forward, (like most modern cars) instead of the whole seat on the passenger side hinging forward. You can't straighten it out?
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  6. JROSS
    Oct 12, 2001
    281
    Redding, CA
    I could try bending it, but that would weaken the metal more. Even though the later model seats are a different style, Do they use the same bolt pattern?
  7. dyeager535
    26,980
    They appear to, but thats with a casual glance. Hmm. Now you got me thinking....wrecking yard said my "tub" was an '86, but its got the "latch" provisions for the older seat. Either its not an '86, or the changeover wasn't complete until mid-year in '86. '86 parts manual definitely shows only the sliding seat. I'd imagine they can't bolt in, since there are no reinforced bolt holes on the earlier trucks to mount seat tracks on that side.
    Dorian
