Seat help
Discussion in 'The Garage' started by coptezr, Jun 17, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
  2. coptezr
    Jan 13, 2005
    342
    come on :blush:
  3. 4wheelin4Jesus
    4wheelin4Jesus 1/2 ton status
    Mar 20, 2005
    149
    north carolina
    youve got to choices. you can either fabricate, and weld up new brackets that will match the existing holes in your floor pan. Or, you can set the seat in, drill holles in the floor pans where the holes are in the brackets on the seat. Get some grade a nuts bolts, and washers. then I would recommend welding a good sized steel plate on the underside of your floor pans where the holes are. then drill thru the steel plate. The plate will help distribute the force and load of the seat over a larger area of your floor pans. install the bolts, and wala.
  4. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    Grade 8 bolts, you mean?
  5. 4wheelin4Jesus
    Mar 20, 2005
    149
    north carolina
    yup, those will work too. :)
  6. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    Ive mounted all types of seats in chevy trucks. Easiest way to do it is use factory mounting points on the floor. So depending what seats you have in your truck right now I would start with late model blazer seat mounts. They are mainly risers. See how the slider on the ram seats is attached. you might luck out and be able to bolt or weld them right to the risers.
