Seat Question????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by larryboz, Apr 23, 2004.
  1. larryboz
    larryboz Registered Member
    Jun 3, 2001
    89
    Kansas City, Missouri, USA
    Will Seats from an 1986 Blazer fit in a 1979 Blazer? Mostly concerned with the back seat for folding up. The Reason I ask is that I have Brand new seats out of an 86 K5 Blazer and might be buying a 79 K5 Blazer but the seats are junk.
    Larry
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    I *think* you're OK. At the least, you can prolly keep the brackets & stuff from the '79 and put the '86 seats on top of them. The '79 might have the high-back seats, or might have the low-backs more common in earlier years (anybody know when the change was)?
    I'm pretty sure the floor pattern is the same from '78 on, so I assume (I know, I know) that the seats wouldn't change.
    -- A
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Uhmm yes and no. You can keep the stock sliders, but the seats will lean farther back. I put seats from a 91 into my 74 and I had to use 1" spacers in the back of the mounting brackets to even them out some. Also, I had to weld flat plat to my stock brackets and drill holes through them to mount the new seats with. The seats will sit a couple inches higher than stock. I like them sitting a little higher because it gives a better field of view.
    You can swap the seats, but you may have to do some bracket modification to make them fit correctly. I'm glad I did mine! /forums/images/graemlins/waytogo.gif
