Seatbelt beaper...won't go off
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, May 26, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Seatbelt beaper...won\'t go off
    This just happened in the past couple of days, outta nowhere. The only way to make the beep stop is to have the drivers side seatbelt hooked up, even when the truck is turned off. This isn't a serious problem just an annoying one. Is there a wire I can cut or fuse I can pull to get rid of the beep all together?
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Re: Seatbelt beaper...won\'t go off
    all you have to do is unbolt it from the floor you will see the wire should be white/black (at least mine was) and disconnect it.
  3. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    It's on the driver's side, BTW...The buckle part, on the floor by the console...Mine isn't hooked up cause I can't find the other end... and I dont' have any beep. or buzz or whatever ya call it.
    Brandy
