Seating races in a 14 bolt hub
Discussion in 'The Garage' started by BigCountryx, Jul 6, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    While swaping to discs I decided to rebuild the hubs on my 14ff. The question that I have is, once I seat the outer race enough to reinstall the snapring, should I back seat it against that snapring or leave the slight bit of gap there? The gap is hardly enough to get your fingernail in, but it seems to me there should be no gap there. Although before I removed the old race, I did not notice it being tight to the snapring.
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I would seat the race. Any remaining gap can close after you've torqued the nuts allowing the hub to become loose.
  3. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    my thoughts exactly, just looking for someone to back up my thinking. Thanks
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, seat it in the same direction that the tapered bearing will be pushing it. Otherwise you'll notice the wheel wobbling after a short drive. :eek1:
