Seats
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Feb 6, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I wanna get some seats from a junkyard, from what kind of NEWER model trucks/suvs will bolt right in? Are there any seats in newer model trucks whos brackets are bolted not welded into the floor that i can just take out and bolt into my floor? Thanks much
    87 Custom Deluxe
    305/Sm465/ NP208
    4.56 , 35" BFG Muds, CatCo Cat & Series 40 delta flow 3" tips.
    6"Springs, Tranny, & Engine coming soon.
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I have heard that the newer Tahoes, Escalades and the like have seats that will work but it was my understanding that you'd just use the seat with your existing floor hardware. Hopefully someone will chime in and set us straight.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2>http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  3. dyeager535
    26,980
    Just need to check if the newer seats are bolted to the floor brackets, or welded.
    Cars, the interchange with other GM stuff was/is easy. Unbolt the seat from the tracks, and put the new seat on the tracks that were in your vehicle. Apparently GM didn't change the seat pattern much. At worst, you'd have to fab up some brackets.
    I'd probably stick with GM vehicles if I were trying to find an easy interchange. What about Camaro seats or something similar?
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
