SEC rear tire bumper
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefjerky, Sep 3, 2001.
  1. beefjerky
    beefjerky Registered Member
    Feb 14, 2001
    64
    anybody know anything about sec rear tire carrier? good or bad deal?
    thanks
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I looked into them.I have to admit.,they make top quality stuff but I was quoted $350-450 bucks.That was alittle steep for me.I'm sure you get what you pay for,but still,it was too much for my poor butt!
    <font color=green>BobK<font color=green>
  3. beefjerky
    Feb 14, 2001
    64
    thanks for the reply. 450 is alot of dough, but it does get that damn tire out of there. do you know of anyother leads or ideas?
    rob86blazer
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  5. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I too have given SEC a thought or two but in the long run I'll just mite make mine Rockstomper has a bearing just for the tire carrier for forty bucks. If you have access to a welder it's not bad idea. Eric
    <a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/>http://cethern.tripod.com/erics-home-page-and-other-stuff/</a>
    AMSOIL Dealer # 529948
    Cethern@interfold.com
  6. J.C.Staley
    J.C.Staley Registered Member
    Sep 23, 2000
    71
    Utah
    I've got the full SEC rear bumper and tire carrier. Very well built. If you buy it you won't regret it. Keep in mind that most of the time you get what you pay for so if you pay premium you are more likely to only pay once. Keep in mind this is from someone with out the tools, knowledge or connections to make it myself.
  7. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I built mine myself using plumbing pipe from a construction job, a throwout bearing for the pivot point and some 1/2 inch steel from another construction job. Various parts bolts and stuff from the hardware store. Check it out in the members rides.
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  8. MudTruk
    MudTruk Registered Member
    Jul 21, 2001
    32
    Norman, Oklahoma
    Mreetz, sweet bumper! How heavy is that wide flage? Looks pretty heavy. Also, how did you attach (latch) the swing arm to the bumper itself? It all looks good and I would like to build one myself, very similar to yours.
    pete
    Gotta go, before ya show!
  9. Mreetz
    Jun 26, 2001
    1,282
    How heavy is what? Looks like you and I are in the same business!!
    1984 K-5
    4" lift
    35x12.5 MTs
  10. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    You might also try Kennesaw Mountain Accessories. They did a review of their front/rear bumps on www.off-road.com. At any rate, I ordered a front bump from them and will post pics and do a mini-review when I get mine. Maybe it'll help, I dunno. =|
    Jason
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  11. hawglet
    hawglet 1/2 ton status
    Aug 4, 2000
    265
    Hastings,NE
    That bumper looks sweat. I've got a design but I need to figure out how to latch the tire to the bumper. How did you build the latch? With what?etc. Congrats. If you can put a closeup pic or some kind of sketch of the latch it would help greatly, to several of us!!!! Thanks.
    Thanks,
    Greg Gayman
    Hawglet
    Stovie
    hawglet@excite.com
  12. Mreetz
    Jun 26, 2001
    1,282
    By latch do you mean opposite of the pivot point? I'm building that tonight and will get pix of it then!
    1984 K-5
    4" lift
    35x12.5 MTs
  13. beefjerky
    Feb 14, 2001
    64
    do you mean the bearing for the swing arm? does the sec bumper have this bearing or is it just a big bolt?
  14. beefjerky
    Feb 14, 2001
    64
    does the tire swing arm move smoothly? was the installation easy? about how much does the entire bumper weigh? any options that i should consider?
    thanks
  15. beefjerky
    Feb 14, 2001
    64
    no welder on this end. sounds like you have the plan. how did it turn out?
  16. beefjerky
    Feb 14, 2001
    64
    i thought those bumpers were mostly for jeeps? any noticeable difference from the SEC bumper to the kennesaw mtn accessories?
    thanks
  17. beefjerky
    Feb 14, 2001
    64
    are you a member of the ore bushhackers? about how many members go on the runs? still looking for details on the bumper. i just want to get that damn tire out of the truck.
  18. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I really wanted to go with the SEC bumpers... I would have to but the shipped killed the deal... might ask them about the shipping before you get to the point where you really want them and then you end up like me [​IMG]
    How can I miss you if you won't go away? [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>www.chevycagal.homestead.com/steph.html</a>
    &lt;&gt;&lt; 1 Timothy 4:12 &gt;&lt;&gt;
  19. J.C.Staley
    Sep 23, 2000
    71
    Utah
    Beefjerky; the installation was extremely easy. Take the old one off, put the new one one. Everything matched up perfectly. When I mounted the front bumper I had to use my high lift to spread the frame rails about 1/16th inch, that was the only modification I had to make mounting either one. Not sure of the weight. I could lift it with out too much trouble but a little help was nice to put it on. I do like the newer system Fredd has for mounting the high lift jack, vertical instead of horizontal like mine. I don't have the gas can mount but I don't need one. If you carry extra gas you should consider it. The tire mount pivot point is made from a trailer axle and has two sets of roller bearings and a zirk fitting. It couldn't be smoother and should last forever. Hope this helps.
  20. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    I'm pretty sure that SEC has a bearing also for the swing arm.
