Second gen chevy to cummins power, how-to post
Discussion in '1982-Present GM Diesel' started by camiswelding, Nov 20, 2004.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I have been researching a cummins for k trucks for the last year and have some conversion questions
    I have learned that there is several ways to go, please feel free to critque what I have learned. I have only seen one truck like mine done with a cummins and although it ran like it was on fire, the conversion was not sano and involved some backyard engineering... I am interested in doing it sano enough that someone would look at it and think... gm did it that way. This post is an attempt to build a how-to thread with good info, not what we think but what we know and what works and what doesnt. Theres no "how-to" manual out there for this conversion but my hope is generating enough response to figure out the right and wrong way to make this conversion, so that those that want to do it have solid direction.
    Your comments will be incorporated into this thread so please visit from time to time for updates.
    This is what I have learned...
    1) Get the used cummins adapter,starter and misc pieces from a p30 step van that had the 3.9/th400 in them (such as what Jamie Avant from Diesel Depot, P.O. Box 228, Sandersville, Georgia 31082,(800) 553-8192, (email@avasalv@mylink.net) sells his "kit" for about 400)
    I have been told that this setup tilts the 5.9 in the engine compartment approx 10 degrees... I am also told this is not a problem, but is noticable... I also assume this "tilt" doesnt affect a standard transmission as much as an auto if you elect to tilt the tranny and not the motor?
    I dont think the auto would like being tilted... the manual stick could be bent to make it come straight thru the floor and the gears would still receive full lubrication (I believe)
    The reason for the tilt in the GM adapters is actually very simple. It was the only way that Cummins could repower P-30 step vans without major work like lowering motor mounts and dropping the tranny lower. The 10* tilt was deemed acceptable by Cummins, and with the lean would fit perfectly in the van's engine compartment. No GM P-30 step van left the factory with a Cummins in it, they were all repowered, most of them replaced 350's, 6.2 equipped bread vans were left alone for the most part.
    2) buying a new and spendy adapter from cummins ( not the way to go so Im told)
    3) custom machining my own adapter using outside machine shop help... why reinvent the wheel unless one has to.
    4) Buying a universal kit from fordcummins (406) 755-8878 www.fordcummins.com) (they have yet to answer their phone or email, and their calif shop, which is close in distance to me, has yet to open) this one has universal motor mounts in it. Its about 400 as well but it does not include the tranny adapter. The kit has some general directions and some misc. brackets for the alternator and water necks to adapt to radiators other than dodge.
    5) Going all dodge running gear OR getting an adapter to work with a chevy 205 from Advance adapters, www.advanceadapters.com , or the like... this means linkage work to adapt the dodge 727 or newer dodge tranny to the
    chevy ..unless this is the only way to get the motor to sit level) Obviously if you have a stick you can go the nv4500 route and that makes the conversion easier.
    It appears going all dodge might be the best way to go... use a 2nd gen cummins and a gen 1 dodge transfer case ,model 205 passenger drop, and a dodge tranny... perhaps for me a built torqueflite 727 since I have a gear vendors overdrive. This way the motor and adapters are all setup for each other and the 205 already fits the chevy transfer case crossmember.
    First gens dodges received 727's from 89 to 91 with the 205 pass side drop.
    First gens then received 518's non lockup convertors from 91.5 to 93 with the 205 pass side drop.
    205's from auto's received a smaller input shaft then the ones that came from manual trucks.
    Some people have put later model lockup/OD autos between a first gen engine and a 205.The lock-up and non lock up converter trannys take a different tranny adapter about 3/4 of an inch thicker for the lock up version
    The 518 is a 727 with an OD unit. The od unit can be upgraded to handle a good running cummins. The 518 is a little longer because of the od unit. I would think it would be an expensive but wise upgrade to go to a lock up convertor. I have heard that some 727's had lock up covertors, but I have no idea what application those were in, and if they will bolt to a cummins or not.
    I'm in favor of using the entire Dodge powertrain. Two basic phases; fabricate the mounts (including strengthening the frame if necessary), and do the mess around with wiring, hydraulic, and linkage. I'd use an overdrive/lockup converter, rather than an aftermarket overdrive.
    People who have done diesel swaps report that in most cases allowing 1/4" of clearance to obstructions, is acceptable
    I'd remove the front end, set the drivetrain more or less in the hole, and start cutting things to make it fit. Then remove the drivetrain and fix the firewall and frame. I would consider making mounts that bolt to the stock pads on both the engine and frame, as I felt that the pads had been engineered to take the loads.
    Once the drivetrain is installed, then there is the task of hooking up all the little things. Just take one thing at a time By using the entire Dodge drivetrain, there will be a number of things to do, but each one is pretty basic. For instance, the ignition wire will need to be hooked to the injector rather than to the coil. You can use your alternator, but you might have to do the mess around with the mount (and belt if the Dodge has a serpentine system). The Cummins power steering pump can be plumbed into the Saginaw box and brakes, if they're hydraulic. The throttle will just be a longer cable. You will have to have hoses made to adapt the Dodge A/C compressor.
    You'll need to do whatever it takes to get plenty of cooling.
    If needed, I'd consider a water to air charge air cooler rather than skimping on a radiator.
    You'll see very little (if any) performance increase with larger than a 3" system.
    I'd suspect that the stock fuel pump would work nicely as a lift pump.
    You'll probably need to work on sound deadening, as the early Cummins are quite noisy.
    It's been my experience (half a dozen engine swaps) that it's far better to get the whole engine donor vehicle. Between the donor and recipient vehicles, there are usually all the parts needed. If you just get the engine, then there are many trips to purchase items, and the expense skyrockets. It's all the little things that kill you. Battery cables, driveshaft yokes, shift linkage, pulleys, air cleaners, throttle cables, exhaust pipes, diesel pre heat relay, vacuum pump, etc., etc., etc.
    You'll probably have to double shock the front end and add a leaf or two. A nice thing about an inline engine is that there is not the usual clearance problems with steering, and exhaust manifolds.
    Someone that has done some engine swaps will have to answer the engine adapter question. I believe there is a difference in the 24 valves to the old twelve valves. I understand that guys going to 6 speeds in an old truck need a different adapter, starter on the block. But I do not know if that applies to auto's or not.
    after doing the above one should be to be ready to possibly....
    a) Install up to a 3 inch bodylift, as the engine hits the firewall otherwise... perhaps a smaller lift and/or a cowl hood can be utilized. Not everyone has had to do a body lift to mount their 6bt's, it really depends on how the motor mounts are set up and how much axle clearance you have for the oil pan
    b)run electric fans as there is insufficient space for an engine driven one ... it would be really great to use the stock dodge fan but everyone says clearance is an issue. You can't get enough cooling ability
    c) make brackets for chevy hydroboost to fit the front of the cummins
    d)ditto for gm alternator and a/c, or adapt dodge. p/s on the 6bt can be adapted to the chevy box
    e) depending on what cummins selected prepare to do some wire surgery
    as I understand it the earlier 12v 6BT motors are the easiest to install.. the full on electrically controlled ones... which require the computer(s) to work.. are much more difficult because of the lack of compatability to the chevy wiring
    And again, all 6bt's are turbo'd. Thats what the "t" stands for. 12 valves are not computer controlled, 24 valves are. The early (think W-series Dodge) used the VE pumps, which are fine until you want to bomb the motor. Later 12 valves (think dodge 94-98.5) had the P-series pumps, which deleiver an insane ammount of fuel, and if you wanted to bomb the motor, this is the pump you would need. Installation of either a VE equipped 6bt or a P-pumped motor is going to be the same. No matter what you should run an intercooler, whether the donor motor came with one or not. Its not a "must" but is highly recomended. VE pumps are more than enough to run stock or do a mild build, but they do have their limitations
    f)TBI chevy trucks 89-91 have electric fuel pumps in the tanks... which interface ok I assume?
    g)trim a framerail where the starter hits? Perhaps the front crossmember as well? Maybe an entire new crossmember to prevent the crank or pulleys from hitting... Boxing may be needed for strength to prevent torque twist?
    Anyone have info on this?
    h)the cummins weighs in at 1100 pounds so the front suspension should be in good shape and perhaps need a leaf.
    i)find a radiator that works well for the cummins... maybe a chevy diesel radiator or a high dollar BB "be cool" aluminum custom one
    (Im not sure where the outlets need to be best suited to the cummins? anyone?)
    j) custom exhaust.... while I have a 3 inch currently and this is what I saw on the converted truck one would have to assume the conversion could benefit from a 4 inch... hard to find a local shop to bend 4 inch unless they specialize in bigger truck exhausts. After some research it appears 3 inch is acceptable and the expense of trying to fit a 4 inch in an umbombed motor probably isnt worth it.
    Pros for the conversion
    1)Saves the chevy which is easy to work on and comes apart with a 9/16 wrench, and has a solid front axle
    2)Your current truck paid for, is like new,or in good rebuildable shape
    3)Satisfaction of having a nice and fairly unique piece of equipment if done sano
    4) Here in California a conversion can use any diesel, post the year of the truck, be checked by a referree, and then be reregistered as a diesel and thus NO SMOG (currently... although smogging diesels in california will probably come to pass) (This info was gained directly from the California Air Resources Board (800) 242-4450 )
    Cons to the conversion
    1) Putting money into a 15 year old or older vehicles with no airbags, no hi tech,leaf spring suspension and which was at the end of its production lifespan with all the fit and finish problems that creates
    2)Wont recoup the conversion cost at possible resale or totalling accident
    3) the cost of the conversion... it could easily exceed 10k on a super sano job with new or reman'd parts. If the motor was bombed at all there could be powertrain issues with the rear end... and overdriving the brakes etc...
    If your running gear was worn out and you could get a motor/running gear cheaply then the conversion might make financial sense. Remember to look at the payout... my big block avgs 7.7 mpg towing 10k pounds... if a ctd gets double the mileage then the payout would be a very long time... years... but then again this probably isnt the reason one is doing the swap... its more for the challenge of it.
    So conversion gurus ,,, give me your thoughts...
    many many thanks for the answers/questions that will come out of this thread
    THIS THREAD WILL BE UPDATED AS INFO BECOMES AVAILABLE
    cam
    ps.. the following ck5 mmbers have CTD converted trucks
    Ronniew4wd
    laketex
    stomper
    crewcab59 (also makes custom cummins to chevy motor mounts)
  2. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Re: 89 v3500 conversion to cummins/ My post over at TDR/long
    A few things that i can answer.
    1.) Yes, the adapter from P-30 step vans clock either the motor or trans 10*, noticeable but fine. This is IMHO the best way to go, parts are cheaper, and are factory Cummins.
    2.a. Not everybody who has done the swap has had to run a 3" BL, some have gotten away with 1", or a fiberglass cowl hood.
    b. Yes, electric fans would be most likely needed.
    c. Not sure about the 6bt, but i know 4bt's have the power steering pumps built into the front of the motor. Would make plumbing very simple, just run the lines to the Cummins pump. Like i said, im not possitive about the 6bt though.
    e. All 6bt's and ISB's are turbo's. You cant get a non-turbo cummins in a highway vehicle, you can in some equipment and generators, but not in an OTR vehicle.
    Id answer more right now, but i need to get back to work on my own truck before i run out of daylight.
  3. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Re: 89 v3500 conversion to cummins, how-to post
    This thread should hopefully become a resource for anyone wanting to swap a CTD into their Chevy, so I'm making it sticky.
    Cam, good luck with the research and the swap and please update this thread as you make progress. /forums/images/graemlins/waytogo.gif
    Rene
  4. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    Power steering pump is build in in my 6bt too. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  5. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Cam, maybe as you confirm stuff you could edit your original post so all the pertinent info is in one post...rather than scattered throughout what could be a long thread.
    Just a thought.
    Rene
  6. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    I didn´t want to take the space of this post but if you want the pics here just tell me or just put them here.
    My C-30 has:
    a 6bt from a 96 Dodge /forums/images/graemlins/dunno.gif
    a NV 4500 from the same Dodge /forums/images/graemlins/dunno.gif
    Chevy radiator Gasoline truck /forums/images/graemlins/dunno.gif
    No fan yet,don´t need (winter)
    No body lift,cutout a little piece of crossmember /forums/images/graemlins/dunno.gif maybe different thing on 4x4
    4" exhaust all the way from the turbo
    The intercooler has been removed but is coming back soon I hope.
    Bought it like this /forums/images/graemlins/crazy.gif.
  7. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Here are a bunch of my pics from my swap.
    I have more but I need to comment on them and just don't have time right now. But I will when I get a chance.
    Brett
  8. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Absolutely beautiful, I hope you can come wheeling down here when you get it finished, I would love to see that in action.
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Great pics Brett... they really help...
    could you please detail a little more about your conversion when you get the chance... what problems you have encountered and how you overcame them...
    thanks
    cam
    I have a Perkins not a Cummins but I know it's the same dimensions and output as the early cummins.
    1" BL would have done but opted for a hood scoop.
    The crossmembers were butchered (I bought the truck already done), and then reinforced for structural integrity.
    A Ford radiator has the right uotputs, no Chevy radiator would work, it's the oposite sides for inlet and outlet.
    If you don't want to switch to hydraboost, you could put a mechanical vacuum pump like on mine, and hook it to a small vacuum tank, works great. /forums/images/graemlins/thumb.gif
    I got mine with no fans and it worked fine on highway but once I started on trails I had to put fans, started with one 12" on one side and it's fine for most of times except really hot days where now I am going to add the second 12" fan.
    I have the SM465 with the special belhousing so no tilt to the motor. And my engine is 1300lbs so I have a 5 leave rough contry 2" lift spring and it's SMOOOTH. /forums/images/graemlins/rotfl.gif
  10. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  11. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    cummins 4bt cpl 858 specs
    NON intercooled
    dry weight 700
    hp 105
    tq 265
    gvw 16000lbs (4x2)
    length w/o mech fan 26"
    height 32"
    width 27"
    16cm turbo
    the rear sump oil pan starts 10" from rear, and roughly 15" from the front with a height (or hangs down) 5"
    the reason the oil pan is included is the height was an issue with front diff clearance. i do not believe the 6bt is necessary, but i dont have one..... cooling is a non issue on a 4bt. it cools too well with a stock m715 radiator
  12. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    more cummins updates
    This update came in from Steve @ Avalanche Engineering
    For those of you who dont know him his work is an art form... and his rock buggies are beautiful... I consider this info well tested...
    heres his email in response to the thread..
    I have not used the step van adapters but I have seen it done and yes it does tilt the motor noticably. I see no problems in doing this other than aethetics. It does help with hood clearance in the Chevy.
    The swaps I have done have used the Dodge NV4500 or 47RE/RH auto and have then used the '89 to '93 factory Dodge adapters to allow the use of the early Dodge NP205 tranfer case. All have had right hand drop Dana 60 frontends. I have not had to do any surgury to the floor, firewall or frame for starter clearance. You will need to notch the frame for the A/C compressor. I do build a new engine crossmember that incorporates new motor mounts and lowers the engine for hood clearance. (no body lift) With two new holes in the GM tranny crossmember either Dodge tranny bolts down. The stock Cummins power steering pump is fine for the GM hydro boost and I just cap the ports to the vaccuum pump and leave it be. The biggest pain in the whole swap for me is cutting the radiator support for the '97 Dodge intercooler which I mount upside down. It usually takes me about 40 hours to do the swap once i have all the pieces rounded up.
    Good Luck,
    Steve
    Avalanche Engineering, Inc.
    Thanks Steve... cam
  13. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    a/c comp...getting around the frame notching on the pass side
    Attn: 12V into 73-87 GM Conversions
    Installing a 12 Valve into a 73 to 87 GM Pickup and 88 to 91 Crew Cab or Suburban can be a real hassle as far as the stock A/C compressor is concerned coming into contact with the passenger side framerail. While I was reserching other B-series OEM installs I found that Kenworth used the B-series 5.9 in 93-97 K-300 medium duty trucks which has a very narrow frame.
    Upon futher inspection I discovered Cummins offers a A/C comperssor bracket that mounts the compressor up high next to the alternator (part# 3930888) which cures the problem of having to cut or notch the framerail which I've seen alot of people do.
    The bracket costs $80-$100 and replaces the Dodge bottom radiator hose neck-A/C combo. Check it out, you'll love it [​IMG]
  14. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Good job digging that bit of info up Cam, and thanks for continuing to update this thread. :)
    Rene
  15. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    91 V3500 CrewCab 4wd Cummins conversion
    1991 GMC V3500 CrewCab 4wd
    5.9 Cummins,NV4500 ,NP205
    Dana 60, 14 bolt,4.10
    This is my Cummins conversion that I did on my CrewCab which had a 6.2 Diesel w/ Banks turbo kit.I installed a 1994 5.9 Cummins, I made my Engine mounts to bolt to stock 6.2 Diesel frame mounts.As you can see in my photos my Engine sets level and straight.There was no cutting of the firewall and have room for the stock hood.I used a 1994 Dodge intercooler. I used a NV4500 5spd with a Dogde input shaft and a Chevy output to bolt up to my NP205.I have no problems with the conversion,the frame was cut to install A/C compressor in the stock location on the Engine.Cooling Runs 185 degrees all day long, I used the stock Dodge Fan clutch.Radiator is a 2 core Chevy auto mid 83 thu 87 and still have room for the fan to be removed.Exhaust 3'' from turbo past the t-case then to straght 4'' to a 5'' tip.
    I do conversion on the side ,and sell my mounts.
    Let me know if you have questions
    Scott
  16. CrewCab59
    Aug 13, 2005
    483
    Knoxville ,TN
    Ctd
    I have no problems to date,with my conversion except my stock clutch won't hold due to power increase.A stock clutch starts to slip @ 400 lb of torque. My Fuel mileage is 16-18 even with this power
    When I did my conversion I install a custom ground cam and lifters,which lowers EGT by 200 degres,1-2 more mpg ,better torque range.I also install 4000 gov springs, My Boost is 37 psi ,My EGT run 575-600 @ 65mph highest was 1150.
    Cooling has never been a problem 180-185 all day long.
    I am starting a Conversion on a 1996 1/2 4wd burb , 1997 4- door Tahoe 4wd with a straight axle A 1978 ford 4wd.
    I will get photo's of conversions if you guy's want.
    New products comming soon
    New mount for the 88-98 Trucks,Burbs,Tahoe
    Crossmembers 73-91 Chevy, GMC
    Kit form conversion.
  17. utchev
    utchev Registered Member
    Aug 17, 2004
    91
    Salt Lake City.....
    NICE! I want one.....(or should I just do that to a Suburban?)
  18. Stomper
    May 11, 2002
    3,767
    Iowa
    Nicely done :bow: Pictures are always welcome. This is turning into a great recource for the board.
    Here is my Fodge if you'd like to see what you are about to do with the 78'.
  19. CrewCab59
    Aug 13, 2005
    483
    Knoxville ,TN
    Stomper
    Not bad for a Fodge,what did you use for Engine mounts?What year is it?
    Scott
  20. Stomper
    May 11, 2002
    3,767
    Iowa
    I actually bought this one(cheap), I didn't build it. It's a 75' but it has a newer front clip as far as I can tell. It's all dodge except for the body, the frame,axles,trans,t-case, all dodge.
    My plan is to strip it down and put the guts in to a rust free 86' GMC 4x4 CC dually similar to your's.
