Second impresssions with my new engine! 17 lbs. of boost!
Discussion in '1982-Present GM Diesel' started by arveetek, Jun 16, 2005.
  1. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Getting ready to take an RV trip to Fort Worth this weekend...I decided I needed to hook up the trailer and go for a test drive before hitting the road.
    Wow! I've got a lot more power, that's for sure! A lot of the hills around my place used to have me pullling down in second gear, but now I can fly right up the hills in third, not losing any speed at all! I can definitely tell the engine is not laboring at all pulling the 29' trailer around. Maintaing any speed I want is no problem now.
    Boost has increased substantially as well. Before the rebuild, max. boost was 14 psi, with the engine near the governor, EGT's at 1050. Now, I've seen the boost spike past 17 psi! Pulling the trailer up one long hill at 60 mph used to see me at 10-11 psi. Now I see 14-15 psi at the same speed and EGT's are still at 1050. I was worried that EGT's might get out of control wih the extra fuel, but I guess the lower compression allows the boost to build with no problem, keeping the air moving through it.
    The only time EGT's climb above 1050 is if I lug the engine in overdrive, when there's not enough boost to keep the air moving through the engine.
    Water temps might be a problem...engine coolant temp climbs pretty rapidly when pulling hard at high rpm. I might have to upgrade the cooling system some more if I do a lot of towing. It'll be fine for close weekend camping trips. I'll see how it does on the Fort Worth trip.
    I've replaced all the u-joints, but I can't get rid of a drive-line vibration. I'll have to keep working on that one.
    Casey
    Driving a screaming 6.2L turbo diesel with 17 lbs. of boost! :D
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Are you going to have any chances to put this rebuild on a dyno?
