second opinion on drivetrain
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mrprex, Apr 9, 2000.
  1. mrprex
    mrprex Registered Member
    Apr 6, 2000
    27
    Seattle, WA
    I recently bought my '88 Blazer for a semi-project(a toy) and I was trying to identify what components I have. I know what kind of engine but I was looking at the transfer case and I wasn't sure if it was a 205 or a 208. The case is aluminum which led me to believe that it was a 205 and it was misleading as to what numbers I should be looking at to identify them in my manual. Any comments? I also have a four speed manual tranny. I think it is a muncie 4 speed (one granny gear and three speeds). Could someone please set me straight? The motor is a 5.7L 350 with a TBI if that helps. Thanks in advance.
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    If it's an aluminum case, then you have an NP208 which came stock in that truck. The NP205 was a cast iron case with aluminum tail correct guys?
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  3. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    tex is correct. But also, the 205 usually has a bolted on flange for the driveshaft. The 208 has that piece of crap slip yoke. And if nothing has been repalced on the truck, its a 208. I've got one in my 88 TBI'd 350.
    Oh, isn't there a small silver & red ring attached to the t-case? Should be and includes all the info.
    Corey
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  4. mrprex
    Apr 6, 2000
    27
    Seattle, WA
    After reading about the tag I went out and looked at the Transfer case again. You guys are absolutely right about it being a 208 and there is a tag on it. I must have been blind not to see it before. Thanks again.
  5. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    If it was anything like mine it was covered in goo and mud
