secondaries on q-jet
Discussion in 'The Garage' started by K5Redneck33, May 1, 2003.
  1. K5Redneck33
    K5Redneck33 Registered Member
    Aug 31, 2002
    47
    INDIANA
    how do the secondaries on a factory quadrajet work? does the top plate just open up from a vaccumm? i mean i know that the secondaries kick in from the trottle bein open at a certain position but i wasnt sure how the top plate opened, i'd appreciate a reply thanks.. /forums/images/graemlins/k5.gif
  2. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    You is right! When the lower secondary throttle plates open it creates a negative pressure (vacuum) under the secondary air valve (upper spring loaded plates) which causes them to open, thus activating the secondary metering rod cam, lifting the secondary rod hanger/rods letting fuel flow into the secondary main well, to get sucked into the two steel tubes pointing into the secondary venturies just under the secondary air valve, to be burned by the engine and eventually be donated back to nature /forums/images/graemlins/grin.gif. They are spring loaded to reduce the bog when you mash the gas. They are tunable as well, it is kind of a beeatch if you haven't done it before, but it is not thermonuclear science either. Hope this answers your question. Have Fun! Nick
  3. dyeager535
    26,982
    191
    Actually, it's air demand of the engine that creates the force necessary to open the secondaries. Most Q-jets have vacuum cannisters that holds the secondary air valve *shut*. The spring is there to make sure it closes once the demand ceases.
    The shape of the air valve is such that airflow over it will keep it open.
  4. mosesburb
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    We are basically saying the same thing about how the secondaries open. I spoke of negative pressure/vacuum and you spoke of demand. negative-pressure/vacuum=demand="force". As for the secondary vacuum pulloff you refer to, it is there for "fine tuning" the rate of the air valve opening. All Q-jets have the micro spring on the passenger side of the air horn but only some of the Q-Jets have that secondary vacuum pulloff. If a person so desired, for max tuning, the secondary vacuum pulloff could be removed and all secondary air valve functions would be controlled by that little spring. There is a different adjustment procedure with and without the secondary vac pulloff. I guess I didn't mention that some of the Q-jets have a secondary vac pulloff and its functions relative to secondary air valve opening in my original post. Thanks for the catch /forums/images/graemlins/thumb.gif
