Sector shaft adjustment after installation?
Discussion in 'The Garage' started by BigCountryx, Oct 20, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I have a neighbor (been owning his own Mech. shop for 15+ years) He told me that as long as my wheels return to center after a turn, the adjustment is not too tight. When you get it too tight, the wheels will remained turned after you make the turn.
    Anyone here ever heard that before? The only way I have heard of setting the sector shaft was to raise the front , remove the tires, turn the steering shaft back and forth and adjust until it's tight in the center, then back off 'till it lossens again.
    I want to do this right, but I tried his method 'cause it was (I actually tightened the nut to about where my stock one was) and my steering feels much more stable and still returns to center. Before I adjust anymore, I'd like some input on whether this is a good indication or not.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    When I swapped my shafts out, I adjusted it till it felt tight in the middle of the steering cycle, then I back of little by little till it was if I turned it anymore I could feel it got tight. Steering feels fine.
