Sector Shaft seal part #?
Discussion in 'The Garage' started by Hossbaby50, Apr 24, 2005.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Anyone have the part number for the seal on the TOP of the sector shaft? The metal/rubber one that the 4 bolts go threw. I blew mine out today while I was out wheeling. Thanks
    Harley
  2. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    I'm not positive that it is available separately. I can check later this eve or tomorrow at work. If it is not available separately, I *may* (you've seen my garage) have a new one out in the shop you can get.
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sweet. Let me know how the hunt goes. Thanks
    Harley
  4. dyeager535
    26,975
    GM part number for a "kit" containing that seal is listed here, at least I think it is, if I understand which seal you are asking about: http://dyeager535.topcities.com/partsmanual.html (near the bottom)
    gmpartsdirect.com is the place to go if you can wait for shipping, local dealer will probably rob you on $$.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I still got the spare you gave me if ya need it . I have 2 boxes in the garage now , and don't need it .
  6. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    I did you one better this week in Moab. I broke the secter shaft off flush with the gear box dropping into Hellderado. Heard a pop, then the steering wheel just free spun. Fortunatly was able to find a used box in a wrecking yard in town.
    Brent
  7. mosesburb
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    Well, the only "partial" kit that has anything in it that you can use is a pitman kit. It has the lower seals and the upper seal, in this kit, they service as an o-ring. It will work, but I don't like using them as opposed to the shim/seal apparatus that you have. Now the full re-seal kit does contain the correcct shim/seal that you have. Unfortunately it is not cheap. I can look for that one I may have, but it will probably not be tonight as I have some serious studying to do tonight. To give you an idea, it is in the right front corner of the shop, which is an area that hasn't seen thie light of day for many years.
    I'll let you know.
