Sector Shaft Swap
Discussion in 'The Garage' started by 78 k5, Aug 18, 2005.
  1. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    when swaping sector shafts will all two wheel drive shafts fit in a 1990 4wd box or is there a certain year shaft for this style box?
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I wouldn't swear by it, but while replacing the seals on mine, I had to buy the 2wd lit and the guy at NAPA told me that GM used the same steering box on the 89-91 V Blazers and Burbs as it did on its 2wd trucks. No time like the present for someone to verify that. :thinking: :dunno:
  3. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Recently this was discussed and it seems that there are two different power steering sector shafts, a variable ratio and a non-variable ratio. They are not interchangable and I haven't found out how to tell which one you have without pulling the shaft itself.
  4. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Anyone ever tried to swap a car/jeep sector shaft? I have alot of 4wd chevy boxes and a couple of car/jeep ones that bolt to the inside of the frame. The sector shaft appears to be the same...but I won't know untill I actualy try and bolt it up.
  5. 78 k5
    Jul 8, 2004
    261
    Do the chebby 2wd boxes bolt up to the frame in place of the 4wd ones, are is modification required?
    the reason I ask is I am debating on whether or not to buy a reman/salvage 2wd box or just swap shafts for my x-over conversion.
