sector shaft???
Discussion in 'The Garage' started by Bhintz, May 28, 2005.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    ok Ive removing this thing is easy but WTF I took out the 4 bolts and the pitman arm and the thing will move about 3/4 inch but then it feels like somethings holding it in, any suggestions? and Ive searched :confused:
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Make sure the steering wheel is straight. Beyond that, it beats me....BFH if you're not too concerned about the box.
  3. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    I tried a BFH and the box isnt even in the car its the doner 2wd box
  4. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Did you take out the snap ring on the sector shaft.. :D
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    There were never any snap rings on my shafts...?
  6. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    There is a snap ring in there on the lower part of the shaft ..
    when you take the arm off look up into the area where the shaft goes and on the outer area of the shaft is a snap ring..
    Just above the end of the splined area in this pic..
    It is about 1/4-1/8 up into the box above the splines
    Not my pic but you get the idea..
    [​IMG] :) :)
  7. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    well I just took that snap ring out and the f***ing thing still wont go above that 3/4 inch mark I even hit it w/ a sledge a nothing :confused: o and the 5th bolt on top doesnt need to be touched right b/c its and adjustment nut correct???
  8. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    That is all mine took nothing else holds them in that I know of..
    When it moves that 3/4 dose the top cover move at all..(it is all one piece) If not then LIGHTLY tap it up while trying to pry/unstick the top cover..but remeber that is the sealing area too
    That is all I did to both the doner box (on the floor) and the 4x4 box in the rig that I did to get them both out once the cover came up I grabbed it and finshed taping up on the shaft till I could pull it out by the cover
  9. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    yea the cover moves w/ it I cant figure this out for the life of me :confused: :angry1:
  10. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Try moving the cover back and forth while tapping upward on the shaft
    Sorry that this is becoming a pain in the arse.. :(
  11. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Might I ask, why are your trying to remove the sector shaft?
  12. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    AFAIK , the sector shaft must be centred to come out.
    Just crank it full right , left , find centre and it will line up and pull out
    This is what my friend just did the other day to put the 2WD one into the 4X4 steering box for cross over steering.
    Hope this helps , good luck.
    BTW , when you get them out be careful not to turn them or you will have to totally re-build the box
