See if you can figure this one out... **PROBLEM SOLVED**
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thatK30guy, Sep 20, 2003.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    Update 9/24/03: Got the problem fixed today and now the truck has its power back and an even smoother idle as well as running engine.
    Turns out number 1 & 3 plug wires were burned thru the boot as a result of them touching the damn headers. Got 2 new wires and the power came back.
    This is not the first time I've had trouble with the plug wires resting on headers. I've gone thru like 5 sets of wires and nothing seems to work. Right now I've got those Kevlar boots covering the plug boot and they seem to be working good. My next solution to eliminating the burning boots on wires is to switch from straight boots to 90 degree so they will not sit on the headers.
    Anybody else running 90 degree boots on BBC's? /forums/images/graemlins/confused.gif
    The 454 in my K30 runs good and smooth. Idles good and strong. But when I shift into gear (automatic), and start to acclerate, there is absolutely NO power at all. The motor becomes sluggish and backfires slightly. I tried WOT and it would not accelerate like it should. While on the highway, I shifted to nuetral and revved it and the BBC was smooth with no shakes or anything. Shift back to drive and the loss of power came back.
    I've checked the transmission and the fluid is clean and good. It still shifts good hard and crisp. But while doing WOT, 3rd gear did not kick in until I got up to around 60 mph.
    Sounds like the vacuum modulator is acting up? Or something vacuum-ralated with the th400? Any other ideas? /forums/images/graemlins/confused.gif
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Re: See if you can figure this one out...
    check all your vaccuum lines. my dad had a chevy camper with a 400 in it that did the same thing. he changed a $3 check valve, and it fixed it.
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    WES:
    Definately sounds transmission related, check the modulator, and next the TQ-convertor....after building a very strong stroker motor we had the same results and were disappointed in the engine, turned out to be the tranny, the engine is one hot sucker
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    definetly vacuum related, try the modulator first.
  5. txtough
    txtough Registered Member
    Aug 31, 2003
    39
    Lubbock Texas USA
    If your running convertors then don't forget to check for back pressure. The effects are very similar to your problems and are often hard to diag. If all else fails try loosing and dropping your down pipes.
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Had a similar problem on my K10, power -wise. Turned out to be the plug wires. Bought a cheap set from the local parts chain, which solved it. Took them back, and warrantied my original set of good wires (which lasted 5 years BTW). HTH....
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    That just about sounds like the advance is gummed up.
    Smooth at an idle and so forth but under a load loss of power and backfiring.
    A timing light will eliminate that possibility.
    Or the coil could be ready to take a dump on ya.
    What you have described sounds like ignition and/or timing issues.
    Awhile ago my 73 had that little copper button under the coil burn out. It acted just about the same way.
    Idled good but ran like crap under a load. Spitting and sputtering and fell on it's face when the loud pedal was nailed.
    It burned out 2 of those before the coil went out.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    This is exactly what my dad was telling me over the weekend. Was asking how the coil was looking but I haven't had a chance to pull off the cap yet. Will be trying to mess with it Tuesday hopefully. /forums/images/graemlins/thumb.gif
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Problem solved. Go back to the top post and read about it. /forums/images/graemlins/thumb.gif
  10. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Aren't you supposed to run 45* boots on a BBC Westy? Thats what I always had on mine... regardless headers are BRUTAL on wires that aren't made for HI-TEMPS. I bought a set of Taylor wires for like $70 than ran well for an entire year... /forums/images/graemlins/rolleyes.gif
    -Dan
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Plug wires....
    "A blind squirrel gets an acorn once in awhile" /forums/images/graemlins/laugh.gif
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    The Accel wires I used to run were straight boot, but called "vari-angle" since you could bend the boot to the desired angle you needed to clear the headers. I tried 3 sets of those and still burned thru them. /forums/images/graemlins/tongue.gif /forums/images/graemlins/angryfire.gif These "vari-angles" where simply boots you could bend to any angle you needed but they still didn't work for me. Then I found out about the Kevlar boot covers and installed them. Worked like a charm but still the heat can transfer thru them and still heat up the wires. Gotta look for thhose stock factory thin steel wire separator-thingies that bolt to the exhaust manifolds found on stock BBC's.
  13. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    2 notes - #1. Accel wires SUCK in heat... known fact. #2. Accel wires have a LIFETIME WARRANTY! Hope you didn't pay for three seperate sets! /forums/images/graemlins/eek.gif
    -Dan
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I had a single bad plug wire that took me forever to find once. Didn't miss at all unless you really got on it. One day I was reaching down by the side of the motor when it was running and it bit me...found that damn thing quickly.
