Semi-float 14 Bolt
Discussion in 'The Garage' started by IDGMC, Dec 13, 2005.
  1. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    So as some of you may have read i found a great deal on a 14bolt/dana 44 with 4.10 gears for 150.00. Well as it turns out the 14 bolt is a semi float and the dana 44 is a 10 bolt. So what do I do? I'm not hard core but the beef of the FF was sounding pretty nice. Would this swap still be worth doing or should I wait for the next deal? :confused:
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Thats the same first swap I did when I started building my rig. It served me well until I could find a FF. Thats still a good deal for a matching set of 8 lugs.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I would still go for it.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, i'd still do it. What type of wheeling do you do and what size tires do you run now and possibly in the future? A 14SF is a good upgrade and will serve alot of people well who really dont need a 14FF...
  5. IDGMC
    Feb 18, 2000
    150
    Idaho
    Its my daily driver with visions of trail rides and spring time trail bustin....I run a 33" bfg for now don't really see going much bigger untill it becomes just a toy.
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    You'll be fine with that axle! I think it would be good up to at least 38's.. Maybe larger depending on how you wheel.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The 14 bolt SF has internal parts that dwarf the 10 bolt. I swapped in a 6-lug one on our '94 Sub a while back. The axle shafts are mongo, the wheel bearings are huge, etc. Definitely a worthwhile upgrade.
    The difference in strength between a Dana 44 and 10 bolt front is too small to worry about.
