Semi-float k30?
Discussion in 'The Garage' started by PsychoticDeadGuy, Jul 12, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    is there a such thing? i thought k30s only came in full float versions? i found an older body style k30 sitting on the side of the road, the same body style as the full convertable k5s. could it be a dana 60? did chevy ever use any other rear end in the k30s other than the corp 14 bolt? and also what years does this body style fall under? it is also 4wd. dana 60 front?
  2. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    It sounds like someone already swapped out the axles. I did the same thing when my brother needed an engine for his crewcab K30. I got one tons and he got a running 350 and my 3/4 ton axles in exchange :D
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ive seen SRW 88-up c3500's with semi floater rears,
    i dunno how or why, but they are running aorund, see one now and then, all stock untouched company trucks and such,
    dunno,,
  4. dyeager535
    26,980
    Saw the same the other day, SRW '88+, box on the back company truck, 14SF in the rear.
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    its all about the GVWR......you can get a 3/4 rated higher than a 1 ton if you specify options...... I dunno either
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    ya, i went back and looked closer. it was a semi float 14 bolt with a 10 bolt in the front...so i left...wasnt worth my time.
  7. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    or they could have put different emblems on it or a different fender with a k30 emblem
