Send your condolences
Discussion in 'The Garage' started by big pappa b, Sep 23, 2003.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I was emailing BorregoK5 to get some parts and he informed me that his nice 415ci motor decided to blow up on him today and left him stranded in the desert....home safe though...
    RIP 415 /forums/images/graemlins/frown.gif
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ouch! That's worse than my day. Sorry to hear it...
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    damn that is sad news to hear /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
  4. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    a moment of silance please /forums/images/graemlins/frown.gif
  5. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Was it a really old motor or was it a motor cut down in the prime of it's life?? Either way one can look at it as a way to build it bigger, better, stronger, faster. Y'all old folks will get the reference. Good luck to you all.
    Allan
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
  7. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Well that may have something to do with it....... /forums/images/graemlins/rotfl.gif
  8. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I wont know for a week or so what happened, I have too much work to break for the truck. I was in the middle of a return trip from SkiGirl's build up this weekend working through the night and commuting home when about 4am the truck overheated. I had noticed the temp guage had stopped working and said zero so I pulled over in Riverside and checked the guage, and all the fluids (first bad sign /forums/images/graemlins/ears.gif). I found the coolant a little low and filled it, then turned the heater on high and continued on. About half way between Riverside and Lake Elsinoire in the middle of nowhere, the truck started pinging and running a little rough so I quickly pulled it over (second bad sign /forums/images/graemlins/1zhelp.gif). It was 5am, dark, no cell phone (perhaps no service anyhow) cant find my flashlight and obviously over-heating from the steady flow of steam coming out of the radiator overflow bottle. Having a little foresight, I made sure I had 2 jugs of radiator fluid back in Riverside. I knew I was expected to get home in time take to take my boy to school in the morning so I pulled my lever-vent radiator cap ( a new addition before I left and a must in my book now over the simple twist kind). Once things cooled down a bit, I added the two jugs and realized I didnt have enough and had no obvious leaks (third bad sign /forums/images/graemlins/thinking.gif). The truck started rough but the temp guage started working. Given I'm in nowhere, my truck has $7000 of fabricating gear in it with the tube doors and no roof, I wasn't about to leave it for any reason, so I worked my way to the nearest anything. About 5 minues later with everything seeming to go well, the temp starts rising so I pull it over again, same steem. Now its getting light so I ran some basic diagnostics, pulling plugs and found that the number 8 piston has a slightly cleaner plug and when cranked would spray oil/water foam. Thanks to my T-cap style valve cover bolts, I quickly locked the intake closed and exhaust open on the number 8, filled the radiator with Lake Elsinore stream water and drove it to a gas station which eventually had water and a phone. Coolant level was still good but the engine was running alittle rougher than just the missing number 8. I ended up working the truck a ways closer to home with adding coolant every time it overheated and after 5 hours, eventually got it home. I figure the rotating assembly is all good, maybe a cracked bore into the water jacket, maybe a cracked head across the intake and exhaust or hopefully is just a blown head gastket and a mill of the heads. I have a lot of faith in this 415 rotating assembly so I'm no too worried there, speedomotive makes a great product! I do have a set of heads on there which I hadn't manafluxed before the headwork so anything goes there. I'll post on what I find, when I can get to it. Cross your fingers!
  9. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    what the hell did you do...let me know whats up with it and I'll try to give you a hand on what I can... /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Big block time!! /forums/images/graemlins/smile.gif
    Glad to hear you made it home though, that's awesome.
  11. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    That sucks....My last 400 had a similar problem. I had put new S/R heads on it, and drilled the steam holes myself, can't be to hard right?
    When I went to button it back up, the holes I drilled didn't look quite right, but I buttoned it up anyway, thinking it is either gonna work not....
    In the second week while on my way to work, I notice this large white cloud following me, so I pull it over. Checked the anti freeze low. Checked the oil, and chocolate syrup. Time to drag it home.
    I probably could have just fixed the heads and been fine, but I tore the whole thing down and started over. It would have been cheeper to just let the machine shop drill the heads in the first place. Trying to save a buck or two in this case got really expensive.
    Hope it all works out in the end.... /forums/images/graemlins/frown.gif
