Sending unit ground ?
Discussion in 'The Garage' started by tdcombs, Apr 27, 2005.
  1. tdcombs
    tdcombs Registered Member
    Apr 12, 2005
    98
    missouri
    I got a new gas tank with a new sending unit. The ground for the sending unit is not attached anymore. I can see where it was once attached but fell off. I tried sodering it back there and cant get it to stick. If i ruff the metal up with a file or emory cloth will it stick or how do i get it attached?
    Im guessing its galvanized since the soder isnt sticking. :confused:
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Had the same problem. I removed the sending unit and drilled a hole where it use to attach. Then put a round lug on the ground wire and bolted it through the hole. :xmas:
  3. tdcombs
    Apr 12, 2005
    98
    missouri
    Ive thought about doing that just wondering if there is a way to soder it. Probably should just drill a hole and use a self taping bolt to hold it on. But would rather soder it for some reason (probably cause my old sodering gun crapped out and i bought a new one to soder this back on)
  4. dyeager535
    26,979
    How was the ground originally attached?
    I can't imagine GM just used solder to hold it in place. Solder isn't that strong, that needs to be a fairly good strong connection.
    If using a nut/bolt method as suggested, I bet brazing would be a good bet to seal that up good.
  5. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    I've put a lug on the wire, cleaned the pick=up tube(that the hose attaches to) and used a hose clamp to hold the wire to the tube, quick and easy
