seperate air spaces for subs
Discussion in 'Audio' started by terrier72, Dec 27, 2005.
  1. terrier72
    terrier72 1/2 ton status
    Jul 6, 2004
    201
    Greenville, SC
    i am in the process of building a sub box and i was wondering if i needed to seperate the airspace for the subs. Or would it be ok if they just shared the same airspace.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I'm no expert , but I would assume it would make the best sound if they each had their own space with the correct volume .
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    If you will be connecting the subs mono to your amp (using only one channel for both subs), then it's ok to have them share the same airspace. If you be connecting them stereo (using two channels of the amp), then the airspace will need to be seperate.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Werd
    If you have the room, make 2 boxes. You are more free to position them differently. 1 box saves space, and I like the sound a little better.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've alway ran seperate chanbers for each sub regaurdless of a mone block or 2 channel amp.
  6. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Tru dat, You should go with 2 chambers, if one of your subs fails the other one is not affected by the airspace.. I read this somewhere..:crazy:
  7. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    That is correct. With both subs sharing the same airspace, the airspace volume must be double the requirement that is needed for each speaker alone. But, if one speaker fails, you now have only one working sub using the airspace that was meant for two subs. This will likely lead to the second sub bottoming out and failing soon after the first did (unless caught quickly). Also, a divider between the two airspaces works very well as a brace to stiffen the box.
    That being said, its certainly possible to share the same airspace, so long as the considerations mentioned above are taken into account. But as the others have said, its best to have seperate chambers when possible.
  8. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Thanks for explaining.
