Serious head scratching*********PLEASE RESPOND
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Aug 11, 2002.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    OK, as some of you know I wasted a LockRight locker. Unfortunately the place I got it from (5 mos. ago) hasn't got the cajones to warranty it they sent it back to Powertrax to be inspected. I have to drive this blazer tomorrow cos my big bro needs his wheels back. I pulled the spider set out of the front of another blazer I have. Put them in, zipped up the cover filled it with oil. This is the head scratching part...... I can turn the axle shafts but the driveshaft won't turn, when I put the blazer in drive everything works normally. I put the tranny in park..... the axles turn but the shaft doesn't. What the hell is going on!!!!!!! Are the front spiders different? Help me please. This is tooo weird.
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i am scratching my head the same...
    but if it gets you round then just lock in the front to use park...
    or tear it appart again and see if you forgot something...
    i dunno.
    grant /forums/images/icons/confused.gif
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    That is how an open axle operates. BTW, with the lock right, did you make sure you didnt have too much space inside the carrier before you installed it? There is supposed to be a maximum carrier clearance between the side gears of the locker and the carrier housing, if its too big then the teeth can jump over each other when they arent supposed to and cause the damage that occurred.
  4. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    I think the tolerance is .045 off the top of my smoking head. And it was well within the clearance. I drove it around for about an hour and nothing broke or sounded funny. I parked in on a sloped driveway and it didn't roll back. I dunno, maybe it sposed to be that way. It's been sooooo long since I owned an open rear diff I forget.
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Sounds like an open differential to me.
  6. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    But why would the axles turn while the tranny is in park? Are they supposed to do that? I really seriously don't remember!! /forums/images/icons/crazy.gif
  7. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    They will turn, but they are turning in opposite directions arent they? Basicly whats happening is the rear cant turn against itself. Hold one tire and the other wont turn w/ the tranny in park. Pop it into neutral and the tire will turn while holding the other.
    W/ a Posi locker or spool, the axles turn the same direction when one tire is spun because the axles are locked together as one.
  8. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Yeh, I guess it sounds right. I just, I dunno....... maybe if I delete all these posts noone will laff at me later /forums/images/icons/grin.gif /forums/images/icons/laugh.gif /forums/images/icons/wink.gif /forums/images/icons/grin.gif /forums/images/icons/shocked.gif
  9. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    No need to delete. I am sure noone is *hmmpffft* laughing *hehe* at you. BUWAHAHAHAHA! /forums/images/icons/laugh.gif
    No seriously I am just joking around. This is something that I am sure someone has questioned in the past, and will again.
    As they say the only dumb question is the one not asked. Ive got one up myself right now I am sure some people will think Im nuts, but I want some opinions. So we can laff at eachother. Hows that sound. /forums/images/icons/smirk.gif /forums/images/icons/grin.gif
  10. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    I prefer people talking(laffing) about me behind my back..... that way I don't hafta worry about it!!! /forums/images/icons/cool.gif
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    This is a 10-bolt diff, right? Some 10-bolts had 28 spline axles, while others had 30 spline axles. It sounds like you installed side gears with 30 splines, but the axle shafts only have 28 splines. /forums/images/icons/shocked.gif Yank the axle shafts from the same truck that donated the side gears, slip them into your housing, and you should be ready to go. /forums/images/icons/cool.gif
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Ooops! Just noticed that you pulled the side gears from the FRONT of your other truck. Obviously, the axles from that aren't going to work in your rear diff. /forums/images/icons/wink.gif Do you still have the original side gears from the rear diff?
  13. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    I look at it this way....If theyre talking about me theyre giving someone else a rest. LOL!
  14. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Thats a very good idea. But wouldnt he have already twisted the splines out already? He has driven it. Is it close enough to have survived? I have never compared the 2 before.
  15. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    The splines are both 28 spline. I was told a 10 bolt carrier is a 10 bolt carrier is a 10........ Ya know? Everything fits together, just didn't seem right. Everything is roolling like its sposta
  16. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    There actually is a difference in spline count after a certain yr. Im thinking 89. Then it goes to 30 spline.
  17. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    now that i think of it, yes that is an open diff. only one will turn while the trans is in park. both will not turn the same way.
    grant /forums/images/icons/crazy.gif
  18. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The truck won't move with 28 spline axles and 30 spline side gears. The shafts spin inside the side gears. I didn't see that he had driven the truck, just that the tires were spinning when he thought they shouldn't while the truck was jacked up. /forums/images/icons/shocked.gif
  19. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Thats what I figured it would do. Like I said I have never compared them so I wasnt sure.
  20. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I didnt know gm used reverse rotation frontends. i thought they were normal rotation and if you had dual open 10 bolts you had all matching spider gears ( stock truck with same spline count axles ).
