serious noob question
Discussion in 'The Garage' started by JOEDEZZY, May 8, 2006.
  1. JOEDEZZY
    JOEDEZZY 1/2 ton status
    Dec 21, 2005
    155
    TUCSON, AZ
    Ok I've pretty much decided that my transfer case is a 203, judging by what I've read, I am assuming that it has been converted to part time 4 wheel, because the front drive shaft does not turn when it is in high, my question is what is the difference between high, high lock, low and low lock and how do I properly put it in 4 wheel drive (locking hubs,etc..)? Also if it has been converted do I only 4 low now?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Taken from this article http://coloradok5.com/milemarkerpt.shtml which is available from the main page , under product reviews :
    After a part time conversion the shift pattern becomes the following:
    4x4 Low
    2x4 low
    Neutral
    2x4 High (Normal Street use)
    4x4 High
  3. JOEDEZZY
    Dec 21, 2005
    155
    TUCSON, AZ
    Thanks that was definitly helpful, so how do I go about locking in 4 wheel drive? From what I was told, I put the the truck in nuetral, engage the transfer case, lock the hubs, and then back up 15-20 ft to lock everything in, and then to take evrything out, I would put the truck in nuetral, put the transfer case in 2 high, unlock the hubs, and back up 15-20 ft.
