serious question about driveshafts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TxK5Blazer, Mar 31, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I am wanting to lift my 82 K5 6" and would like to know whether the drive shafts need to be legnthend or not some say yes some say no. I would appreciate any help in this matter soon looking to do lift this weekend ....Jason /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    on a K5 a 6" i am (ill say 95%) sure it will require a longer shaft.
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    With a 6" lift, I would say yes.
  4. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    A 6" lift requires almost 2" more length on the driveshaft. If you have a np208 with a slip yoke that's a lot of the yoke pulled out of the transfer case.
  5. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    would it be both driveshafts lengthened or just the rear?
  6. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    You will have to lengthen both. Dropping the t-case an inch will help with length and angle. I VERY temporarily(half a day) had 8" of lift in a short box with the t-case dropped one inch. the shafts worked, but everything was fully extended and would not last long like that. You might get away with 6" and dropped t-case for a while...assumiing that you have the 208.
  7. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    I have a 208 but i guess i will lengthened them two inches if that is correct?
  8. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    it might be possible to have the shop just install a CV on your existing driveshaft between the slip yoke and the driveshaft, and that would give you extra lenth, pluse vib resistance. just my .02 /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    *sigh*
    there is no "one" answer. some don't need it, most do.
  10. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    You'll have to get the truck up on the new springs and make a measurement before you get the drive shaft made. I landed my black k5 on a rock and busted my rear drive shaft so I had to get another one made. Since it wasn't at stock height, I got everything setting where I wanted it in the garage, measured, and took the old drive shaft, yoke, and differential flange down and had the new one made and balanced. I think it was only about 1 1/2" longer than stock for about 4" of lift.
