Serious Question! Do Farts Rise?
Discussion in 'The Lounge' started by Pookster, Apr 28, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Ok, if hot air rises, do Farts rise? Or sink if its denser than air....
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Why don't you experiment and let us know. You can use people at bus stops as test subjects. /forums/images/graemlins/rotfl.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I think they pretty much disperse in every direction. However, they definitely rise, I can tell you that, otherwise you'd never smell 'em.
    On a side note: NEVER drop while wearing chest waders...the only place for it to escape is right past your nose.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I've always wondered why a fart can quickly escape your pants yet a fart will stay under the sheets for hours....
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    You've obviously never taken mass transit in NYC. You cant tell if its the bus that smells, the train that smells, the dead rats in the tunnel that smells, or of someone farts.
    that said, you can still tell. Its just that nobody will ever fess up, they pretend like it never happened!!!
  6. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    I think they linger more so than rise or fall. They must have some sort of sticky quality to them. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    They rise. They also disperse in the air almost instantly touching other atoms.
    I guess it really depends on the weather... If its colder than body temperature, it will rise. If its really hot and muggy, it will likely not rise but instead diffuse even faster in the air atoms bacause of the rate both are moving. If its cooler outside the atoms in the air are moving slower, thus when a 'FART' is released it hits the cooler atoms and reacts by searching for other atoms at the same movement rate (IE temperature) to swap neutons with. Similar to how you can have cool and hot spots in water after going #1. Its take a few minutes for the warmer #1 to disperse in the cooler water. It has a harder time breaking down and swapping neutrons with other atoms, so effectively it has to cool to swap neutons. /forums/images/graemlins/deal.gif So, dispersion is slower. Using this same concept in the air, knowing that heat rises and the average outside temperature is lower than an average humans interal temperature the fart will rise till all of the atoms have cooled and diffused. /forums/images/graemlins/cool.gif
  8. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I'm a snowmobiler in the winter, and you have to wear either a suit or bib's, and a coat to stay warm.
    So I can say from experience, that they definately do rise! Everything purged come's out around the neck hole in the jacket. Whewww /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif That way I get to enjoy? them twice. /forums/images/graemlins/rotfl.gif
  9. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I had to sleep on the top bunk at my friends house when I went to visit her. Her sons room was the only other place to sleep besides the sofa and the dog claimed it. Anyhow that kid farted away like he was trying to power a small country at night. I got to enjoy all of em... so yes they rise....
  10. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    You put it like that and it almost takes the funny out of a fart /forums/images/graemlins/frown.gif /forums/images/graemlins/rotfl.gif
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  12. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Yeah, they rise, i'm always suffocating myself sittin here surfin CK5 and farting reading some of the BS on here. Not sure if my farts or the BS though sometimes. /forums/images/graemlins/rotfl.gif
  13. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    So in effect, every time you fart you create a mini tornado. /forums/images/graemlins/rotfl.gif
  14. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Well when you Fart in the tub they Float to the top /forums/images/graemlins/yikes.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  15. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Air disperses/defuses in water also, So farting the tub, though its fun, is just like bathing in your own poo /forums/images/graemlins/crazy.gif
    As the air passes through the water it makes and breaks chemical bonds with the water particals and the water takes on properties of the air passing through it. Just like an air raider in a fish tank (how do you get air back into the water for the fish to live.... make bubbles! as the bubbles pass through the water they swap nuetrons and water becomes air raided... IE the properties change)
    AH college science classes... we had WAY too much time and WAY too much Alcohol /forums/images/graemlins/shame.gif
  16. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its fun farting while you are in my garage /forums/images/graemlins/histerical.gif
  17. 4xcrazy
    Oct 31, 2003
    9,471
    5
    air raider ??
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/doah.gif
  18. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]I think a crouded elevater would be a better test site. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
