serp belt swap info from vbelt setup
Discussion in 'The Garage' started by sweetk30, Sep 7, 2006.
  1. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    today i ttook my 79 350 and removed all the front drive brackets and pulleys and h20 pump. i then cleaned the front face of the block and heads to remove grease and dirt.
    installed h20 pump from doner 89 burban 350. then installed pass side bracket setup. found only 1 bolt hole not drilled and taped in head. but this should not be a problem as there were 5 and 2 brace rods. so now there is 4 and 2 rods.
    i then installed a a/c delete bracket and pulley. this side also needed a small twek of the fuel line.
    next was the drivers side bracket install. all bolt holes lined up good. installed them and secured the altenator to the bracket. next i need to get a change over plug for the old style to the new style plug.
    next was the p/s pump. i was not sure if this was going to clear as it is a 3 hose hydroboost pump and older resivor. but against all odds. she bolted up perfectly. then i installed the serp belt pulley on the pump.
    next was the h20 pump pulley . last was the main belt. then i changed the thermostat as i needed to change the water neck out for a stright one so it would clear the hose to brace rod for the pass side mount bracket.
    all i can say is you need to do this. its easy and wow is it clean and simple to work on now for a belt change. those multi bolt to adjust v pulley brackets sucked at times.
    took me about 3 hrs to do. if you use the stock hardware to block studs . you will need the inverted torqs bit sockets to remove them and install them easy.
    just go to the junk yard and look for 88-91 blazer/burban/crewcab for the parts. or a 88-up new body style will work also.
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    did you put a reverse fan on as well as a reverse rotation fan clutch?
  3. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    Like stated above I did the same swap and forgot to change fans and had overheating problems. Till I finally figured out the fan was reverse rotation.
  4. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I heard you can also get the pulleys from S series trucks, but they have to be 4.3 motors.
  5. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    That is correct. The brackets and pulleys are the same on the V6.
  6. sweetk30
    Nov 1, 2004
    25,549
    543
    no front clip on truck yet. so no fan yet. just 4 bolts to hold pulley on for now.
    baby steps . baby steps.
  7. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    sweet, i may have to do this since i already have electric fans...
