Serp. idler pully ?
Discussion in 'The Garage' started by big jimmy 91, Jan 28, 2005.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    On my stock 91 350 the plastic idler pully siezed up and self destructed (serpentin belt)
    Does it have to be another plastic one to replace it or can I put in a steel one instead
    Anything wrong with steel over plastic??
    (this pulley is under the AC unit on the block)
    :thinking:
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I just bought a complete serp set up from GM and mine is steel!:grin:
  3. big jimmy 91
    Feb 21, 2004
    639
    How much?
    There was only the one plastic one on my stock set up
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Got it from Summit. mmmmm...can't remember how much at the moment.:blush: Only bought it a few weeks ago....must be getting old!
  5. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    AC Delco 15-4957. This is a complete asm, bolt, washer and pulley.
    Four Seasons 45979. This is a correct steel replacement (pulley only).
    API 7145979. Same as above.
    Gates lists a #38006, but the front of the pulley is not shaped correctly to reuse the washer under the bolt. The washer is not neccessary, but it will contain the pulley in the event of a bearing failure. I don't use these.
  6. big jimmy 91
    Feb 21, 2004
    639
    Thanks for the info :cool1:
    I ended up going to the scrap yard and found a steel pully that fit the application , it was just loose on a shelf full of parts so I don't even know what its from but it seems to be working:saweet: (for only $5.00)
