Serp Setup Questions
Discussion in 'The Garage' started by Drey, Nov 7, 2006.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Will the serpintine setup from a 89 K5 with a 350(Mikeys) work on a 73 SBC 400?
    Its going into a 83 K10 and I plan on keeping my hydroboost setup and Deisel Radiator.
    Im going to eliminate anything Air Conditioner related.
    Im just curious as to whether it will work or not before I hand any cash over to mikey cuz he will no doubt spend it on crappy minnesota beer:rolleyes:
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Don't see why it wouldn't provided you use a serp waterpump and fan.
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes you can use it, i put a serp setup on my 74 350
  4. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    they just are reverse cut or something liek that correct?
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    The water pump and fan spin backwards from v-belt setups. So you need a reverse rotation waterpump and fan, so yes.
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Good that you don't want air since the a/c compressor was disposed of anyways.
    I'm pretty sure the hydroboost won't work with it though...
    Eh well, it's a Minnesotan part, far superior and incompatible with Iowan parts.
  7. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    You can pull the pulleys off both power steering pumps, pull the pumps off their brackets, and switch them around. Then your truck will be just fine with hydroboost :)
    Just realize that there may be a bolt hole or two that doesn't line up, or isn't tapped on your older heads. You want at least three bolts per side holding it on if possible...
    The best setup I've seen to date is from the TPI cars, they have aluminum bracketry that goes from the heads all the way down to the bolt holes just above the oil pan, and all but 1 bolt lines up, and is drilled / tapped. I drilled and tapped the last hole, but would reccomend against it, as I drilled a hole straight through into the water jacket, doh!
  8. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Its getting some aftermarket heads anyway, I may talk to my motor builder about it, I can prolly get Kert to fab me up some brackets too
  9. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I've got the water pump pulley and the crank pulley as well as the belt.
  10. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    hydro boost pump will fit the stock k5 setup. i did it to my 79. only 1 bolt hole on right head wont be there.
  11. goldwing2000
    goldwing2000 Guest
    Sounds like an excellent opportunity for an onboard air setup! Kilby makes a bracket that goes right in place of the serp a/c compressor.
  12. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    This is going to be Drey's "pretty truck" for now, so no need for OBA...until we hack it up and put 40's on it. :haha:
  13. goldwing2000
    goldwing2000 Guest
    Even a pretty truck can benefit from a set of air horns. :waytogo:
  14. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Oh you can just kiss my a$$ mikey. I just want it within the realm of workability still. What good is a truck on 40s gonna be to haul wagons from the farm to town with, or pull a trailer. I was actaully thinking about OBA down the road, would be handy to have for all sorts of things.
    Also the decision has been made in another 50000 miles my 96 S10 blazer will go under the knife and my first trail rig will be in the works
