Serpentine acc. fits....
Discussion in 'The Garage' started by SUBFAN, Dec 4, 2004.
  1. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Will the serpentine set up of my '90 350 fit onto my '72 400???? I haven't had a chance to look if all the bosses are present on both blocks....
    Thanx /forums/images/graemlins/thinking.gif
  2. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Anyone???? /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  3. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    I installed this serpentine kit from Summit, and it lists that it works for 265-400 engines. From what I've researched most of the parts are comparable to 1990 Camaro 5.7L. The kit included all the brackets.
    So I'm guessing your stuff would swap./forums/images/graemlins/dunno.gif
  4. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    should swap, as long as the accessory bolt holes are in the heads, but there is one hole not present on the old pass side head that the bracket uses, but you will be fine without it as long as the braces are used
