SERPENTINE BELT MOTOR IN OLDER CHEVY...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brians 60s, Oct 13, 2001.
  1. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    I have a fresh 350 I am wanting to put in my 73 chevy truck. I dont have the old brackets and accesories, but I do have them from the front of a 88 chevy with the serpentine set-up
    has anyone put this on an older motor? What do you do about the power steering box being old on the truck and newer on the box? What do you do about the lines? I also need to do something about the water pump, since it is reverse rotation. Will the serpentine pully fit on the old water pump? Anything else I should know about? thanks, Brian
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Ask that question on Chevytalk. Try this link.
    http://forums.chevytalk.com/cgi-bin/ubbcgi/forumdisplay.cgi?action=topics&forum=1973-1987+Trucks+|AMP|+Vans&number=45
    There's at least one guy on there that has done this conversion on a c10.
    -- Mike
    <font color=blue> The mud's on it to hide that it's more than one color.[​IMG]
  3. B75k5
    B75k5 Registered Member
    Mar 5, 2000
    53
    Southern Calif
    Go to gmpartsdirect.com and enter part # 12497698.... this will give you all the part numbers you need.
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    You will definetly need the newer water pump cause it is reverse rotation. You'll also need to most likely change ps lines so you can hook it up to the older style gear box... but you can check and see for sure
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  5. James Rustyk5
    James Rustyk5 Registered Member
    Aug 18, 2001
    34
    30 minutes South of San Antonio, Texas
    You will have to use all the front accessorys off of the 88. I am running a serpentine setup off of a 93 truck on my 79 truck and it worked out great. you will need the Water pump, altnator, power steering pump, and the ac compressor off of the 88. you have to change the power steering lines. On mine I cut the steel line end off the high pressure hose that goes to the steering box off of the 88. Then I cut the steel end off of my 79's high pressure and used a compression union. It was a Sunday when I did this so I could not get a hose to correctly maked that day. You ownly have to cut the ends off if it is the older style steering box like my truck.
    James Rustyk5
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Brian, my TPI motor is an old 400 factory motor with the all new serpentine setup on it. The water pump has to be reverse rotation (not reverse flow) and I used the power steering pump off a newer truck. Pics on my site, let me know if you need anything specific taken a pic of. Go for it.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  7. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    This is something I have also been interested in for some time too. Anyone else have comments on this? Does anyone know of a write-up?
    <font color=red>"SETTING OFF ALARMS IN A CITY NEAR YOU!"</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/BigTex-Mean-Machine>http://coloradok5.com/gallery/BigTex-Mean-Machine</a>
  8. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I just installed the GM Kit this last week used the PS pump I had( all GM pumps seam to have the same bolt patern. The kit is really for the car not truck but fits fine. Has a new GM water pump and all the bolts and pulleys that are needed. By the way I bolted this up to a 400 SB with aftermarket heads and it went on like a dream.
    72 Blazer CST 400TPI NV4500 NP203/205
    01 Suburban 2500 4X4 8100
  9. dyeager535
    26,975
    Only thing I can say about serpentine is, if you lose a power steering line, you are going to toast the pump. I NEVER thought about that downside, until a friend lost a hose out in the woods. Not even off-roading, just way out of town, and had no choice but to drive the truck with no PS fluid. I don't think that is a positive. Then again, chances of that happening are...?
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  10. BigTex
    Dec 27, 2000
    974
    South Texas
    How much did that kit cost? Any "hidden" obstacles when installing it?
  11. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    And where did the kit come from? Thanks.
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
